Version 8.3 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Wed Nov 18, 2015 12:02 pm
We are proud to announce the release of new major version 8.3 of VintaSoft Imaging .NET SDK and the related Annotation, PDF,
JPEG2000, DocCleanup Plug-ins and the brand new DICOM Decoder Plug-in.
  • Created ASP.NET MVC4 and HTML5 web controls for viewing and editing images and PDF documents in ASP.NET MVC applications.
  • Added the ability to edit images in ASP.NET applications. At this time are supported the following image processing commands: clear image, crop image, flip image, halftone image, invert image, resize image canvas, resize image, rotate image. The list of available image processing commands can be easily extended, because the library architecture is open.
  • The WPF decoder of XPS files has been created (decoder is located in Vintasoft.Imaging.Wpf.dll assembly).
  • New ASP.NET MVC4 and HTML5 demo applications have been created:
    • ASP.NET MVC Annotation Viewer Demo - ASP.NET MVC application for annotating images and PDF documents.
    • ASP.NET MVC Barcode Reader Demo - ASP.NET MVC application for barcode recognition in images and PDF documents.
    • ASP.NET MVC Image Viewer Demo - ASP.NET MVC application for viewing and editing images.
    • ASP.NET MVC PDF Viewer Demo - ASP.NET MVC application for viewing PDF documents.
  • Additional information about changes in SDK is available here: http://www.vintasoft.com/vsimaging-dotnet-history.html
  • Information about API changes in SDK is available here: http://www.vintasoft.com/docs/vsimaging ... aging.html
  • Added the ability to remove content of PDF document.
  • Added the ability to perform packing of fonts in PDF document.
  • Added the ability to protect text in PDF document against extraction.
  • Added the ability to manage and override the algorithm of PDF content rendering.
  • Added the ability to view, create and edit PDF portfolio.
  • Additional information about changes in Plug-in is available here: http://www.vintasoft.com/vspdf-dotnet-history.html
  • Information about API changes in Plug-in is available here: http://www.vintasoft.com/docs/vsimaging ... 3_Pdf.html
Version 8.3.1.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Mon Dec 07, 2015 2:59 pm
  • ASP.NET MVC
    • Added functions for converting points from screen coordinate space to an image viewer coordinate space, from an image viewer coordinate space to image coordinate space.
    • mproved the image viewer compatibility with touch screens.
  • ASP.NET WebForms
    • Improved the image viewer compatibility with touch screens.
  • Fixed the bug in parser of TrueType fonts.
  • Fixed the bug in algorithm that extracts formatted text from PDF page.
Version 8.3.4.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Tue Jan 19, 2016 9:44 am
  • Improved TIFF decoder.
  • Fixed the bug in PDF decoder.
Version 8.3.5.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Wed Jan 27, 2016 3:19 pm
  • Fixed some minor bugs in PDF renderer.
Version 8.3.6.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Wed Feb 10, 2016 6:02 pm
  • Improved the algorithm that loads damaged PDF documents.
  • Improved the performance of TensorPattern rendering.
  • Fixed the minor bug in PDF page rendering algorithm.
  • API changes:
    • Added the PdfAnnotation.IsVintaSoftAnnotationAppearance property.
      Added the TextSymbol.ContentSymbolCode property.
      Added the PdfFontViewerControl.Symbols property.
      Added the WpfPdfFontViewerControl.Symbols property.
Version 8.3.7.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Fri Feb 19, 2016 11:42 am
  • Fixed regress in parser of TrueType/OpenType fonts.
  • Fixed the bug in decoder of CMYK images.
Version 8.3.8.3 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Tue Mar 01, 2016 2:52 pm
  • Improved the algorithm that restores damaged PDF documents.
Version 8.3.9.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Tue Mar 15, 2016 12:00 pm
  • Improved the image printing.
  • Added new assembly Vintasoft.Imaging.Pdf.Resources.dll. Assembly contains CMap resources, which are necessary for correct decoding of Chinese, Japanese and Korean text. VintaSoft PDF .NET Plug-in (Vintasoft.Imaging.Pdf.dll) loads the assembly automatically if Vintasoft.Imaging.Pdf.dll and the assembly are located in the same folder.
  • Fixed some minor bugs.
Version 8.3.10.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Fri Mar 25, 2016 10:25 am
  • Added support for all predefined Cmap-tables, which are specified in PDF reference, for composite fonts.
  • Added the ability to render vertical text on PDF page.
  • Added support for composite fonts with codes of variable length.
  • Added the ability to pack and obfuscate Type1, CFF and Type3-fonts.
  • Added support for font collections (.ttc).
  • Added the ability to use any font instead of any of standard 14 fonts.
  • Added the ability to search external font by its PostScript name.
  • Fixed the bug in algorithm that parses inline images.
  • Fixed the bug in algorithm that constructs encodings of CIDFontType2-fonts with external font program.
  • Fixed minor bugs in algorithm that constructs encodings of simple fonts.
  • Fixed the bugs in algorithm that parses Type1- and CFF-fonts.
Version 8.3.13.1 of VintaSoft Imaging .NET SDK has been released.
Post by Alex » Thu Apr 21, 2016 2:57 pm
  • Fixed the bug in JPEG decoder.
  • Increased the performance of PostScript functions in PDF documents.
  • Fixed the bug in renderer of PDF images.
