Version 10.0 of VintaSoft Twain .NET SDK has been released.
What's new in this version:
  • Significantly improved the algorithm that acquires images from device. Now the image acquisition algorithm is fully asynchronous.
  • Significantly improved the algorithm that cancels image scanning.
  • Significantly improved the WPF version of SDK.
  • Many major and minor fixes.
Version 10.0.3.1 of VintaSoft Twain .NET SDK has been released.
  • IMPORTANT: Fixed a problem with high CPU usage. Problem presents since version 10.0.0.1.
  • IMPORTANT: Fixed the bug in algorithm that gets compressed image data from device. Bug presents since version 10.0.0.1.
  • Improved the algorithm of Device.AcquireModal method. The ScanFinished element is added to the AqcuireModalState enumeration.
  • Improved the algorithm that raises the Device.ScanFinished event.
  • Fixed a minor bug in image acquisition algorithm. Bug presents since version 10.0.0.1.
  • Some improvements in demo applications.
Version 10.0.4.3 of VintaSoft Twain .NET SDK has been released.
  • Added the ability to select language and country for TWAIN device manager and device using the parameters of DeviceManager class.
  • Now TWAIN Advanced Demo detects country and language for TWAIN device manager.
Version 10.0.5.1 of VintaSoft Twain .NET SDK has been released.
  • Fixed minor bug in DeviceManager class.
  • Fixed minor bug in TIFF encoder.
Version 10.0.6.1 of VintaSoft Twain .NET SDK has been released.
  • Improved the algorithm that synchroniously acquires images from device.
  • Improved the algorithm that cancels image acquisition.
  • Improved the algorithm that stops image acquisition.
  • Improved the PDF encoder.
  • Fixed the minor bug in TIFF encoder.
Version 10.0.8.1 of VintaSoft Twain .NET SDK has been released.
  • Improved the algorithm, which works with device capabilities, for better compatibility with Plustek scanners.
Version 10.0.9.1 of VintaSoft Twain .NET SDK has been released.
  • Added support for LZW and Packbits compression in image data received from scanner in Memory transfer mode.
Version 10.0.10.1 of VintaSoft Twain .NET SDK has been released.
  • Fixed the bug in algorithm that retrieves an extended information about acquired image from scanner.
