Edit inside tag
rstrickland1958
Edit inside tag
Post by rstrickland1958 » Thu Feb 08, 2018 4:31 am
For the annotation tags that the user can edit inside, the user has to first click on the tag to open the edit area. Is there any way for the tag to open directly in edit mode after the user places the tag on the viewer?
Re: Edit inside tag
Post by Alex » Thu Feb 08, 2018 7:59 pm
I am not sure I have understood your question. You are editing the annotation properties using the property grid and now you want to edit annotation properties programmatically. Am I right?
Please read information about annotations in the documentation: https://www.vintasoft.com/docs/vsimagin ... ction.html
rstrickland1958
Re: Edit inside tag
Post by rstrickland1958 » Thu Feb 08, 2018 8:39 pm
Sorry for the confusion.
I select an annotation that allows text and place the annotation on the viewer. Based on how I have use this type of annotation, I have to double click on the annotation to open up edit region that allows me to enter my text. I then click outside this edit region to close the region and update the annotation. I need for the edit region to come up without having to double click with the mouse on the annotation. I was going to see if there is a key sequence from the keyboard that will do this or if there is a property for the annotation that automatically opens the edit region.
Re: Edit inside tag
Post by Alex » Fri Feb 09, 2018 10:11 am
Here is code snippet that shows how to specify that one mouse click must be used for activating the text box of text annotation:
/// Determines that one mouse click must be used for activating the text box of text annotation.
/// <param name="textAnnotationView">Text annotation.</param>
public void UseOneMouseClickForActivatingTextAnnotationTexBox(
    Vintasoft.Imaging.Annotation.UI.TextAnnotationView textAnnotationView)
    // get the rectangular transformer for text annotation from text annotation
    Vintasoft.Imaging.Annotation.UI.VisualTools.UserInteraction.RectangularTextAnnotationTransformer rectangularTextAnnotationTransformer =
        textAnnotationView.TextTransformer;
    // get the text box transformer from the rectangular transformer for text annotation
    Vintasoft.Imaging.UI.VisualTools.UserInteraction.TextObjectTextBoxTransformer textObjectTextBoxTransformer =
        rectangularTextAnnotationTransformer.TextBoxTransformer;
    // specify that text box must be shown when user clicked on text annotation
    textObjectTextBoxTransformer.ActivateClickCount = 1;
More info about the text box transfomer please see in the TextObjectTextBoxTransformer class:
https://www.vintasoft.com/docs/vsimagin ... ormer.html
