Console: Convert a DICOM file to JPEG images.
This topic contains C# code sample that shows how to convert a DICOM file to JPEG images:
using System;
namespace ConsoleApplication1
    class Program
            if (args.Length != 1)
                Console.WriteLine("ConsoleApplication1.exe <path_to_DICOM_file>");
                return;
            string dicomFilePath = args[0];
            if (!System.IO.File.Exists(dicomFilePath))
                Console.WriteLine(string.Format("File \"{0}\" does not exist.", dicomFilePath));
                return;
            // convert a DICOM file to a JPEG files
            ConvertDicomToJpeg(dicomFilePath);
        /// Converts a DICOM file to a JPEG files.
        /// <param name="dicomFileName">Name of the input DICOM file.</param>
        public static void ConvertDicomToJpeg(string dicomFileName)
            // create image collection
            using (Vintasoft.Imaging.ImageCollection imageCollection =
                new Vintasoft.Imaging.ImageCollection())
                // add DICOM file to the collection
                imageCollection.Add(dicomFileName);
                // create JPEG encoder
                using (Vintasoft.Imaging.Codecs.Encoders.JpegEncoder jpegEncoder =
                    new Vintasoft.Imaging.Codecs.Encoders.JpegEncoder())
                    // set the quality for output JPEG files
                    jpegEncoder.Settings.Quality = 70;
                    for (int i = 0; i < imageCollection.Count; i++)
                        // save image as JPEG file
                        imageCollection[i].Save(string.Format("page{0}.jpg", i), jpegEncoder);
                        Console.Write(".");
                Console.WriteLine(string.Format("{0} DICOM frames are saved.", imageCollection.Count));
                // clear and dispose images
                imageCollection.ClearAndDisposeItems();
Source codes of console application for VintaSoft Imaging .NET SDK 14.0 can be downloaded from here.
