New features request for version 5.0 of VintaSoftBarcode.NET
Post by Alex » Thu Apr 01, 2010 4:03 pm
New features which will be available in version 5.0 of VintaSoftBarcode.NET SDK:
  • Read/write of Aztec barcodes
  • Ability to read images (image resources) with barcodes from PDF documents (1.0-1.7)
  • Ability to specify resolution for generated images with barcodes
Daniel.Dority
Re: New features request for version 5.0 of VintaSoftBarcode.NET
Post by Daniel.Dority » Wed Sep 01, 2010 4:48 pm
Alex,
Do you have a rough idea when the feature for reading PDF's will be released?
Also will it be compatible with 64 bit environments?
Daniel M. Dority
Post by Alex » Fri Sep 03, 2010 8:16 am
Hello Daniel,
Version 5.2 of VintaSoftBarcode.NET SDK already allows to read image resources from PDF documents versions 1.0-1.7.
You need to use VintaSoftPDF.NET Plug-in if you need to render pages of PDF documents.
Version 5.2 of VintaSoftBarcode.NET SDK is compatible with 64-bit environment.
