New features request for version 5.3 of VintaSoftBarcode.NET
Post by Alex » Tue Apr 20, 2010 1:17 pm
New features which will be available in version 5.3 of VintaSoftBarcode.NET SDK:
  • ability to read and write some data flags and special characters
  • .NET barcode reader improvements
  • some minor optimizations
reproprint
Re: New features request for version 5.3 of VintaSoftBarcode.NET
Post by reproprint » Wed Aug 25, 2010 4:20 pm
What about support for Laetus Farmacode? Are there any plans to implement this.
Regards
Jaka
Yuri
Post by Yuri » Thu Aug 26, 2010 1:00 pm
thanks for your suggestion. We'll add support for Laetus Farmacodes in next comming version.
Regards
reproprint
Post by reproprint » Thu Aug 26, 2010 6:30 pm
Great. When will be the next release published?
Jaka
Yuri
Post by Yuri » Fri Aug 27, 2010 10:58 am
The exactly date is not known at this time.
Most probably next version will be available at the beginning of the 4th quarter.
Regards
reproprint
Post by reproprint » Tue Oct 05, 2010 7:52 pm
Are there any news about the release date of version 5.3 of VintaSoftBarcode.NET yet?
Regards
reproprint
Post by reproprint » Tue Oct 26, 2010 11:45 am
Is there any echo?
Regards
jaka
Post by Alex » Tue Oct 26, 2010 1:01 pm
Hello Jaka,
Version 5.3 of VintaSoftBarcode.NET SDK will be available next month.
Maksim
Post by Maksim » Mon Nov 22, 2010 5:06 pm
Need the ability to interrupt barcode scanning.
Sometimes barcode recognition with Automatic settings and low Scan interval takes several seconds and in some scenarios needs to be interrupted.
If there were a delegate that is being called periodically from within ReadBarcodes method (similarly to Graphics.DrawImageAbort http://msdn.microsoft.com/en-us/library/ms142043.aspx) that would be great.
Another option is to use Task Parallel Library's cancellation token (http://msdn.microsoft.com/en-us/library/dd997364.aspx).
This would be the preferred method in Framework 4.0.
Regards,
Maks
Post by Alex » Wed Nov 24, 2010 11:43 am
Hello Maks,
Thank you for suggestion, we will add progress indicator of barcode reading process and ability to interrupt of barcode reading process in version 6.0 of VintaSoftBarcode.NET SDK. Version 5.3 will be available at the beginning of December 2010.
