Updating a Multipage Tiff
Douglas911
Post by Douglas911 » Thu Jun 10, 2010 3:20 am
I really struggled with this but I found that the following code worked for me.
Create a windows form that has an Imageviewer1 component and an OpenFileDialog1
I have three buttons. Load, Change, Save.
Some of the code I hand typed, but I believe I have it correct.
Hope this helps
Douglas Shonley
Computer Help
Sturgis, SD
Imports System.Windows.Forms
Imports System.Drawing
Imports System.IO
Imports Vintasoft.Imaging
Imports Vintasoft.Imaging.Codecs
Imports Vintasoft.Imaging.Codecs.Tiff
Public Class frmTesting
   Dim vTiff As New TiffFile
   Dim vCurrentFileName as String
   Dim vTempFile2 as String = "C:\Temp\Tempfile2.tiff"
 Private Sub butLoad_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butLoad.Click
        If OpenFileDialog1.ShowDialog = Windows.Forms.DialogResult.OK Then
            vCurrentFileName = OpenFileDialog1.FileName
        Else
            Exit Sub
        'Load into vTiff
        vTiff = New TiffFile(vCurrentFileName)
        'Move Images into ImageViewer
        For x As Integer = 0 To vTiff.Pages.Count - 1
            ImageViewer1.Images.Add(vTiff.Pages(x).GetImage)
        Next
    End Sub
    Private Sub butChange_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butChange.Click
        ImageViewer1.Images(1).Rotate(90)
    End Sub
    Private Sub butSave_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles butSave.Click
        'Clear out present vTiff
        vTiff.Pages.Clear()
        butSave.Text = "Updating Tiff"
        butSave.Update()
        'Move images from ImageViewer1 to vTiff
        For x As Integer = 0 To ImageViewer1.Images.Count - 1
            vTiff.Pages.Add(ImageViewer1.Images.Item(x))
        Next
        butSave.Text = "Saving"
        butSave.Update()
        'Save vTiff to a temporary file
        vTiff.Save(vTempFile2)
        butSave.Text = "Disposing"
        butSave.Update()
        'Clean out the tiff
        vTiff.Dispose()
        'Clean out the ImageViewer
        ImageViewer1.Images.ClearAndDisposeItems()
        butSave.Text = "Copying"
        butSave.Update()
        'Copy the tempfile over the top of original file
        My.Computer.FileSystem.CopyFile(vTempFile2, vCurrentFileName, True)
        butSave.Text = "Done"
    End Sub
End Class
Re: Updating a Multipage Tiff
Post by Alex » Thu Jun 10, 2010 2:55 pm
Hello Douglas,
Your code is correct but not optimal!
Version 4.2 of VintaSoftImaging.NET SDK is released today. This version now allows to save processed and/or annotated images back to the source using ImageCollection, please see our ImageViewer and Annotation Demos.
