Scanning multiple pages
srikanthgaddala
Post by srikanthgaddala » Fri Sep 03, 2010 1:30 pm
Hi All,
I have a requirement that i need to scan a batch(probably more than 10 pages) but i want to save it as a single pdf document.
Example if i have scanned 10 pages from my scanner i need to save it as a sample.pdf where this sample.pdf contains those 10 pages in it.
Please help me to solve this.Thank you in advance..
if possible send me the code.
Srikanth.G
Re: Scanning multiple pages
Post by Alex » Fri Sep 03, 2010 1:41 pm
Hello Srikanth,
Please read this FAQ:
http://www.vintasoft.com/docs/vstwain-d ... eeder.html
srikanthgaddala
Post by srikanthgaddala » Fri Sep 03, 2010 2:10 pm
Really thanks for your quick reply.
but my case is i need to save it as a pdf file.
let me explain you my requirement clearly.I have a C# application.when i click on scan button it should scan the multiple pages and should be saved as a single pdf file.Like i have explained in the previous post.
Thanks in advance
Sincerely ......
Srikanth Gaddala
Post by Alex » Fri Sep 03, 2010 2:19 pm
Just change extension in filename from ".tif" to ".pdf" and acquired images will be saved in PDF document.
Code from FAQ:
e.Image.Save("c:\multipage.tif")
New code:
e.Image.Save("c:\multipage.pdf")
srikanthgaddala
Post by srikanthgaddala » Fri Sep 03, 2010 2:30 pm
Thanks again Alex,
where can i find this DeviceManager and Device classes.i am getting the errors.under which name space they will be available?
Sincerely ,,,,,
Srikanth Gaddala
Post by Alex » Fri Sep 03, 2010 2:45 pm
You need to use version 7.0 of VintaSoftTwain.NET SDK.
srikanthgaddala
Post by srikanthgaddala » Fri Sep 03, 2010 3:02 pm
yeah thanks Alex,
i found it.....
thank you very much..
sincerely..
Srikanth Gaddala
