Size of an StampAnnotation
MichaelHerrmanns
Post by MichaelHerrmanns » Tue Dec 20, 2011 3:50 pm
how can I create a Stampannotation with an userdefinded size on mouse click.
I try with this code:
Dim ann As New StampAnnotation()
ann.Text = "Rubber stamp"
ann.ZOrder = _zOrder
ann.Size = New SizeF(450, 800)
_zOrder += 1
Try
    annotationViewer1.BuildAnnotation(ann)
Catch ex As InvalidOperationException
    MessageBox.Show(ex.Message, "Building annotation")
End Try
The stamp has only a size of (1,1) on release the mousebutton.
Have anyone a solution for this problem?
regards
Michael
Re: Size of an Stampannotation
Post by Alex » Thu Dec 22, 2011 3:01 pm
Hello Michael,
Now you should add annotation to the annotation collection of image and later change size of annotation if necessary.
Here is a snippet of code:
_zOrder += 1
Try
   annotationViewer1.Annotations(0).Add(ann)
End Try
What is your goal? Do you need to specify minimal size of annotation before building? Could you explain me, step by step, how do you imagine this?
MichaelHerrmanns
Post by MichaelHerrmanns » Tue Jan 03, 2012 9:52 am
thank you for your reply. I am late, butI was on my christmas vacation.
#Do you need to specify minimal size of annotation before building?
Yes thats my goal. The User create with an stamp a stampannotation and this should be in
default size. After that the user can change the size of this stamp.
I hope itis clear what I want to do.
Best Regards
Michael
MichaelHerrmanns
Post by MichaelHerrmanns » Wed Jan 11, 2012 3:38 pm
I have one additional question.
If I you your code:
only on the first page of my document can take the annotation.
How can I tell them to build the annotation on the selected page?
Best regards
Michael
Post by Alex » Thu Jan 12, 2012 4:53 pm
Hello Michael,
Here is a code snippet for VB.NET:
Dim pageIndex As Integer = 0
annotationViewer1.Annotations(pageIndex).Add(ann)
and here is a code snippet for C#:
int pageIndex = 0;
annotationViewer1.Annotations[pageIndex].Add(ann);
MichaelHerrmanns
Post by MichaelHerrmanns » Fri Jan 13, 2012 11:25 am
thank you for your tip.
It works now.
Best regards
Michael
