CustomAnnotation - don't want to select annot. after draw
Junhui
Post by Junhui » Tue Jan 31, 2012 8:37 am
I've made custom annotation class which overrides LinesAnnotation.
After drawing that annotation(customed) on annotationviewer, it selected automatically.
I want to select custom annotation manually, but not select automatically after drawing.
Can I do that with OnFinishBuilding(System.Drawing.PointF point)? Or anotherway?
class MyLineAnnotation : LinesAnnotation
protected override void OnBuilding(MouseEventArgs e, MouseActions action)
protected override void OnFinishBuilding(System.Drawing.PointF point)
base.OnFinishBuilding(point);
// how can I reach the goal...
Best Regards,
Jun Hee.
Re: CustomAnnotation - don't want to select annot. after dra
Post by Alex » Tue Jan 31, 2012 11:04 am
Hello Jun,
You can set the selected annotation in the annotation viewer using the SelectedAnnotation property of the AnnotationViewer.
Junhui
Post by Junhui » Mon Feb 06, 2012 10:30 am
I handled this issue with codes below,
[DllImport("user32.dll")]
public static extern void mouse_event(int dwFlags, int dx, int dy, int cButtons, int dwExtaInfo);
and I generated 'mouse_event(0x8 | 0x10, 0, 0, 0, 0);' after draw.
Best regards,
Jun Hee.
Post by Alex » Mon Feb 06, 2012 11:40 am
Hello Jun,
It is the possible solution but not the best.
Why have you not used the SelectedAnnotation property?
