zoomselection
MichaelHerrmanns
zoomselection
Post by MichaelHerrmanns » Mon Feb 20, 2012 12:54 pm
I want to use to zoomselection feature.
If an user doubleclick on the image a rectangle with mousepoint as centre should be zoomed.
Private Sub InteropUserControl_DoubleClick(ByVal sender As Object, ByVal e As System.EventArgs) Handles AnnotationViewer1.DoubleClick
        Dim eMouse As MouseEventArgs
        If AnnotationViewer1.SelectionMode = Vintasoft.Annotation.SelectionMode.AnnotationView Then
            eMouse = DirectCast(e, MouseEventArgs)
            If _zoomSelection Is Nothing Then
                _zoomSelection = New ZoomSelection(_imageViewer)
            AnnotationViewer1.VisualTool = _zoomSelection
            _mouseX = eMouse.X.ToString
            _mouseY = eMouse.Y.ToString
            _zoomSelection.Rectangle = New Rectangle(CInt(eMouse.X - 300), CInt(eMouse.Y - 200), 600, 400)
            _zoomSelection.Zoom()
    End Sub
But never the zoom appears on the selected recangle or the rectangle not created on the place the user has clicked.
Any suggestions?
best regards
Michael
Re: zoomselection
Post by Alex » Tue Feb 21, 2012 2:43 pm
Hello Michael,
You need to use the following code:
private void ZoomAfterDoubleClick()
    ImageViewer1.DoubleClick += new EventHandler(ImageViewer1_DoubleClick);
    ImageViewer1.Images.Add(Path.Combine(WorkDir, "testimage.tif"));
void ImageViewer1_DoubleClick(object sender, EventArgs e)
    MouseEventArgs eMouse;
    eMouse = e as MouseEventArgs;
    Point pointOnImage = imageViewer1.PointToImage(eMouse.Location);
    ZoomSelection selection = new ZoomSelection(ImageViewer1);
    ImageViewer1.VisualTool = selection;
    selection.Rectangle = new Rectangle(pointOnImage.X - 300, pointOnImage.Y - 200, 600, 400);
    selection.Zoom();
MichaelHerrmanns
Re: zoomselection
Post by MichaelHerrmanns » Tue Feb 28, 2012 11:04 pm
thats it.
Now it works.
Thank you
best regards
Michael
