Question to solve exception "Capability is not supported"
mierli
Post by mierli » Mon Aug 26, 2013 7:13 pm
Hello
I have a problem to work with the property "device.PageSize".
For one scanner the property works fine, and I can set the PageSize to "PageSize.A4" - the scanner is the Canon Lide 500f.
On an other scanner I get an exception during the runtime or debug - "Capability is not supported - Name= ISupportedSizes".
This is a HP Office-Jet Pro 8500.
How I could check this property whether the the "PageSize" is valid for one scanner or not valid for other scanners; so I could solved this problem - but I don't know, how I could check for valid/or not valid.
Please have you a clue for my problem?
Many thanks in advance & best regards
Michael
Re: Question to solve exception "Capability is not supported
Post by Alex » Wed Aug 28, 2013 9:33 am
Hello Michael,
You need check supported page sizes using the Device.GetSupportedPageSizes method before setting value of the PageSize property.
mierli
Post by mierli » Wed Aug 28, 2013 11:30 am
Hello Alex
thanks for your reply.
If I call this method "Device.GetSupportedPageSize()", I get also an exception. So now I add a workaround to check in a try/catch-block with the "GetSupportedPageSize()"-method the pageSize-property.
               bool pageSizeIsSupported = true;
                    var x = _device.GetSupportedPageSizes();
                catch (TwainDeviceCapabilityException)
                    pageSizeIsSupported = false;
And after this try/catch-block, I set my properties or don't set the pageSize-property.
Best regards, Michael
