Device is Already Opened
simp513
Post by simp513 » Thu Dec 19, 2013 11:40 pm
My scan code:
private bool Scan()
    bool ret = false;
    string lastStatus = "None";
        if (File.Exists(@"C:\Scan.tif"))
            File.Delete(@"C:\Scan.tif");
        _sessionCount = 0;
        _imageCount = 0;
        // open the device manager
        _deviceManager.Open();
        // if no devices are found in the system
        if (_deviceManager.Devices.Count == 0)
            MessageBox.Show("No devices found.");
            return ret;
        // get reference to current device
        _device = _deviceManager.Devices.Current;
        // subscribe to the device events
        SubscribeToDeviceEvents();
        // set scanning settings
        _device.ShowUI = false;
        _device.Open();
        //_device.PixelType = PixelType.BW;
        _device.UnitOfMeasure = UnitOfMeasure.Inches;
        _device.DisableAfterAcquire = true;
        _device.TransferMode = TransferMode.Memory;
        _device.AcquiredImages.AutoClean = true;
        // get reference to object that manipulates DuplexEnabled capability
        DeviceCapability duplexEnabledCap = _deviceManager.Devices.Current.Capabilities.Find(DeviceCapabilityId.DuplexEnabled);
        // if DuplexEnabled capability supported
        if (duplexEnabledCap != null)
            // set value of DuplexEnabled capability
            duplexEnabledCap.SetValue(checkBox1.Checked);
        string tiffFilename = @"C:\scan.tif";
        // acquire images from device
        AcquireModalState acquireModalState = AcquireModalState.None;
        AcquiredImage acquiredImage = null;
        do
            acquireModalState = _device.AcquireModal();
            switch (acquireModalState)
                case AcquireModalState.ImageAcquired:
                    lastStatus = "ImageAcquired";
                    acquiredImage = _device.AcquiredImages.Last;
                    // despeckle/deskew/detect border
                    acquiredImage.Despeckle(8, 25, 30, 400);
                    acquiredImage.Deskew(BorderColor.AutoDetect, 5, 5);
                    acquiredImage.DetectBorder(5);
                    // add image to multipage TIFF file if image is not blank
                    if (!acquiredImage.IsBlank(0.02f))
                        acquiredImage.Save(tiffFilename);
                    ret = true;
                    break;
                case AcquireModalState.ScanCompleted:
                    lastStatus = "ScanCompleted";
                    ret = true;
                    //Copy Images
                    //Clear images
                    _device.AcquiredImages.Clear();
                    // close the device
                    _device.Close();
                    // close the device manager
                    _deviceManager.Close();
                    break;
                case AcquireModalState.ScanCanceled:
                case AcquireModalState.ScanFailed:
                    lastStatus = "ScanFailed";
                    ret = false;
                    //Copy Images
                    //Clear images
                    // close the device
                    _device.Close();
                    break;
        while (acquireModalState != AcquireModalState.None);
        UnsubscribeFromDeviceEvents();
        if (acquiredImage != null)
            acquiredImage.Dispose();
    catch (TwainException ex)
        MessageBox.Show(ex.Message , "Error", MessageBoxButtons.OK, MessageBoxIcon.Error); //ERROR Comes here
    return ret;
How can I stop getting "Device is Already Opened"? It seems to happen randomly, maybe 1 page maybe on the 5th scan. Any help?
Re: Device is Already Opened
Post by Alex » Fri Dec 20, 2013 8:58 am
Please debug your application, check the device status each time when you start an image acquisition and check why device is opened when you starting the image acquisition.
simp513
Post by simp513 » Fri Dec 20, 2013 4:05 pm
ok, where would you suggest I insert that?
Post by Alex » Sat Dec 21, 2013 8:59 am
Your Scan() method opens TWAIN device manager, selects and opens the device, acquires image from device, closes the device and TWAIN device manager. You may have the "Device is Already Opened" error only if you called method Scan() twice at the same time. Are you use Scan() method in multi-threading environment? Or maybe you do not disable the "Scan" button when it clicked and user can click the button twice? Please examine your code.
