when setting to color jpg, I get 0kb file
quicoli
Post by quicoli » Sat Dec 06, 2014 4:27 am
Friends,
I'm using a Kodak i2600. My scanning is set to memory transfer mode: when I set PixelType to BW or Gray, everything is okay. But, when I set to RGB, the following event is producing an empty file, 0kb file...
 private void _device_ImageAcquired(object sender, ImageAcquiredEventArgs e)
            var filename ='test.jpg";
            if (!e.Image.IsBlank(0.01f))
                e.Image.Save(filename);
I don't know what is wrong.... someone could point some direction?
thank you
Re: when setting to color jpg, I get 0kb file
Post by Alex » Sat Dec 06, 2014 8:08 am
I think you are using the evaluation version of SDK. Evaluation version of SDK does not allow to save RGB image to a JPEG file.
