Scan stays on the progress dialog .. Scanning page 1
alexei
Post by alexei » Sat Sep 23, 2017 12:11 am
I'm using the Vintasoft ActiveX Twain on a windows 10 through internet explorer 11.
When scanning with the Epson GT-S55 , I can select the scanner on the dialogbox and the scanner scans the first page, but hangs on the DialogBog. And the browser hangs.
Did someone have this behavior before?
regards,
Alexei
Re: Scan stays on the progress dialog .. Scanning page 1
Post by Alex » Mon Sep 25, 2017 5:18 pm
Hi Alexey,
... but hangs on the DialogBog. And the browser hangs.
For understanding the problem we need to see your code and log-file, which is generated by ActiveX. Please send a snippet of your code and log-file to support@vintasoft.com.
Here is article that describes how to generate log-file: https://www.vintasoft.com/docs/vstwain/ ... oting.html
alexei
Post by alexei » Wed Oct 18, 2017 10:06 pm
the issue is with the Windows 10 most probably, I'm using a Windows Surface Pro 4. but when I use a normal laptop with windows 7 it works perfectly.
Post by Alex » Fri Oct 20, 2017 5:24 pm
Hi Alexei,
Thank you for information. I think you need to update TWAIN driver for your scanner.
alexei
Post by alexei » Thu Dec 21, 2017 8:58 pm
The issue is that the scanner does not have a driver for windows 10. the latest driver update dates from 2013.
Most probalby the scanner is too old and the * Epson, will not invest in new drivers anymore.
Alexei
