PdfAnnotationTool / InteractionMode and Hidden Annotations
Posted: Sun Jun 24, 2018 10:03 pm
I'm trying to solve the following Problem:
- In InteractionMode = Markup , everything works like i want to, but only single selection is possible
- In Interactionmode = Edit, mutliple selection works, but also Hidden Annotations are displayed and the User can move them.
In the PDF we handle (created by another Application) Links to other Parts of the PDF are PdfLinkAnnotations and invisible,
but with Edit Mode, they can be selected and moved.
This will confuse the End-User and lead to Links not working anymore at the Place they were put in the first place.
Can you give me pointers, if it's possible to disable certain Annotations from being selected/moved by Edit Mode.
At the moment ,the only workaround would be to remove the Annotations before activating the Edit Mode ,and add them again later.
I would be also acceptable if i can interfere in the Movement of the Annotations (cancel the action or similar)
