Sticky Note CreatedBy- CreatedDate Display
Posted: Thu Sep 27, 2018 4:00 pm
by nickstarlight
I have looked through the Sticky Note Annotations, and see the CreatedBy and Created Date properties.
I have been attempting to display those properties preferably above, or even below the note itself.
Is there currently a way of accomplishing this, and how?
Re: Sticky Note CreatedBy- CreatedDate Display
Posted: Thu Sep 27, 2018 5:40 pm
by Yuri
Set the text of StickyNote when you create it:
StickyNoteAnnotationData stickyNote = new StickyNoteAnnotationData();
stickyNote.FillBrush = new AnnotationSolidBrush(Color.Yellow);
stickyNote.CreatedBy = Environment.UserName;
stickyNote.CollapsedTextData.Text = string.Format("CreatedBy '{0}', {1}", stickyNote.CreatedBy, stickyNote.CreationTime);
then add it into the image annotation collection or begin to build it.
Regards,
Yuri
Posted: Thu Sep 27, 2018 5:53 pm
by nickstarlight
Thank you, Yuri. Though my concern with setting the CollapsedTextData.Text with the created by and time information would be that the user would be able to edit that information.
Logically in the code, when enter the ExpandedTextData from the StickyNote it allows you to edit the text from the CollapsedTextData.
Posted: Fri Sep 28, 2018 10:33 am
by Yuri
Hi again,
Please describe in precise details the behavior and logic you want to get from StickyNoteAnnotation. And so we will be able to provide you a quick solution.
Regards,
Yuri
