64bit arithmetic overflow
daveinhull
Post by daveinhull » Sat Jan 05, 2019 6:03 pm
I only use VSwain for internal home use on one application and have been using it successfully for a few years under 32bit. I have now come to move to 64bit and I'm getting an arithmetic overflow when I come to open the device.
I'm writing using VS2017 in VB and I believe I have selected the 64bit version of the DLL.
Any quick thoughts?
Many thanks in advance
Dave
EDIT: some other information, this is in the call stack
> Vintasoft.Twain.dll!Vintasoft.Twain.DeviceCapability.GetUsageMode() Unknown
Re: 64bit arithmetic overflow
Post by Alex » Wed Jan 09, 2019 12:49 pm
For understanding the problem we need analyze log-file, which is generated by SDK.
You can generate log-file as follows:
  • Enable logging (add the line below to code of your application):
    TwainEnvironment.EnableDebugging("d:\vstwain.log")
  • Run your application.
  • Send us a log-file to support@vintasoft.com
