DICOM: Multiplanar reconstruction
boyan243
Post by boyan243 »
Dear Sir
i bought your vintasoft sdk with dicom plug in.
i would like to add function mip , minip and avg.
we can use mip and minip in Documation is showed .
So how to change modes of slice rendering .
Thanks your sir
MPR - Intensity value.
MIP - Maximum intensity projection along thickness of a slice.
MinIP - Minimum intensity projection along thickness of a slice.
Avg - Average intensity value along thickness of a slice.
Preview3D - Maximum intensity value along thickness of a slice, that dependents from distance within slice. Preview 3D mode that uses only to preview the whole MPR image.
Re: DICOM: Multiplanar reconstruction
Please do the following test:
1. Run VintaSoft DICOM MPR Viewer Demo ("[SdkInstallPath]\VintaSoft\Imaging .NET v12.3\Bin\DotNet4\AnyCPU\DicomMprViewerDemo.exe").
2. Open DICOM files for MPR.
3. Select "MPR => Saggital/Coronal/Axial" menu => "2D MPR" dialog will appear.
4. Select "View => Settings" menu => "MPR settings" dialog will appear.
5. Change "Rendering mode" parameter (MPR, MIP, MinIP, Avg, Preview3D) and see the result.
Source codes of VintaSoft DICOM MPR Viewer Demo can be found in installation of VintaSoft Imaging .NET SDK: "[SdkInstallPath]\VintaSoft\Imaging .NET v12.3\Examples\WinForms\CSharp\DicomMprViewerDemo\"
boyan243
Post by boyan243 »
i have version only VSImagingNet11_0
how to do mip in version 11
You can do the same steps for VintaSoft Imaging .NET SDK 11.0. Version 11.0 also has VintaSoft DICOM MPR Viewer Demo.
