New features request for version 2.1 of VintaSoftImaging.NET
Post by Alex » Thu Oct 16, 2008 8:19 am
Version 2.1 of VintaSoftImaging.NET Library will have the following features:
  • Add, edit and delete tags of TIFF file
charlessymmonds
Re: New features request for version 2.1 of VintaSoftImaging.NET
Post by charlessymmonds » Tue Oct 21, 2008 3:45 am
VintaSoftImageing is a great tool with wonderful performance, though I do have some suggestions for improvement to minimize user interaction and provide greater programmatic control.
Ability to select an area within an image programmatically.
Ability to zoom to existing selection (whether selected by user or in source code) programmatically.
Fire event on the image viewer control when a selection is made. This event should be triggered whether the selection was made by the user or in source code.
The parameter passed to this event would provide coordinates of the selection made as an alternative to querying the Rectangle property of the underlying zoom tool.
Ability to assign selected index of thumbnail control. Currently this property is read only.To illustrate the need, the ImageViewerDemo has different values for Focused and Hovered ThumbNailAppearance properties. Clicking on a thumbnail to select a page, then using the numeric UpDown control to change the page leaves the thumbnail control with 2 different thumbnails highlighted with potentially different appearances. It appears the only way to synchronize the 2 focus highlights is by clicking on a thumbnail.
Provide tool support for both mouse buttons. For example, it appears that panning can only be done via the left mouse button.
Post by Alex » Tue Oct 21, 2008 10:13 am
Hello Charles,
Thank you for suggestions. New version of library will contain features you suggested.
I have a question about "Ability to assign selected index of thumbnail control". You want to get a write access to the SelectedIndices property of the ThumbnailViewer. Am I right?
citytroop
Post by citytroop » Tue Oct 21, 2008 11:35 am
Alex hi,
In relation to the DragDropSelection tool it would be very usefull to be able to :
1. Set the background color for DragAndDrop tool.
2. Copy the selection to the internal buffer of library and later insert it
to another image or
3. If the annotationviewer is used to create an annotation based on the DragDrop selection to be able to cut copy or paste elsewhere.
4. When croping part of an image to crop and display in a new page/image rather than just displaying the cropped part.
Regards
Dimitris
Post by Alex » Wed Oct 22, 2008 3:19 pm
Hello Dimitris,
alfonsofung
Post by alfonsofung » Wed Dec 10, 2008 5:07 am
Alex, how about
Sorting of images that looks alike in the ThumbnailsViewer/AnnotationThumbNailsViewer;
Batch stamping/Annotating of multiple-images, thumbnails of which having been selected in the ThumbnailsViewer;
Adding a tag property to each thumbnail which is also the tag of the image shown in the ImageViewer;
Built-in sortable/groupable grid of the annotations, each column being fetched from a CSV stored as text of the annotation.
Alfonso
Post by Alex » Tue Dec 16, 2008 11:34 am
Hello Alfonso,
Please give me more info about features you suggested.
-> 1. Sorting of images that looks alike in the ThumbnailsViewer/AnnotationThumbNailsViewer;
What do you mean?
-> 2. Batch stamping/Annotating of multiple-images, thumbnails of which having been selected in the ThumbnailsViewer;
Our "Stamp Images Demo" (http://www.vintasoft.com/vsannotation-d ... mples.html) does not suit your needs?
-> 3. Adding a tag property to each thumbnail which is also the tag of the image shown in the ImageViewer;
Do you want to store information associated with thumbnail?
-> 4. Built-in sortable/groupable grid of the annotations, each column being fetched from a CSV stored
-> as text of the annotation.
Please explain.
alfonsofung
Post by alfonsofung » Wed Jan 14, 2009 8:05 pm
Please add a label under each thumbnail to allow showing image number/index/tag
Post by Alex » Fri Jan 16, 2009 10:03 am
Hi Alfonso,
Thank you for suggestion. We will try to add this feature to our library in next version (maybe not in version 2.1).
whc325
Post by whc325 » Thu Jan 22, 2009 2:42 am
ICC Profile cababilities: Colorspace conversion, profile embedding.
Thanks.
