New features request for version 2.2 of VintaSoftImaging.NET
Version 2.2 of VintaSoftImaging.NET Library will have the following features:
  • Anti-aliasing preview mode for the image viewer.
  • New image processing functions.
mvockerodt
Re: New features request for version 2.2 of VintaSoftImaging.NET
Post by mvockerodt »
Hello.
1) It would be nice to have the viewer (optionally) use some type of interpolation when zooming below 1:1 size, This will reduce jaggies and improve the appearance. For 1-bit images, this is usually called "scale to grey" but the same can be said of colour images as well. It's probably equivlent to using the GDI+ Graphics.DrawImage method with a higher-quality InterpolationMode selected, though for 1-bit images a custom implementation would probably be better & faster.
2)I would like to be able to change the Cursor that a selection (or maybe: any visual tool) uses at any time, so I can indicate visually that a different operation will be performed. For example: pressing CTRL might change to a magnifier with a minus sign in it whereas without CTRL it display a magnifier with a + sign, just like Adobe Acrobat reader.
3) An event that fires when the user releases the button after making a selection would be great.
4) Following on from 3): ZoomSelection might have an option so that the zoom happens immediately on releasing the button instead of when you click in the region.
5) Being able to programatically set/clear the section rectangle would be great. Currently I can only clear it by changing CurrentTool.
Regards,
Martin
Hello Martin,
Thank you for your suggestions. Please see comments below.
2) I would like to be able to change the Cursor that a selection (or maybe: any visual tool) uses at any time, so I can indicate visually that a different operation will be performed. For example: pressing CTRL might change to a magnifier with a minus sign in it whereas without CTRL it display a magnifier with a + sign, just like Adobe Acrobat reader.
Ok, we will add these features to new version of library.
Please see the SelectionChanged event of the SelectionBase class in documentation.
Please see the Zoom method of the ZoomSelection class in documentation. Zoom process can be controlled programmatically.
Please see the Rectangle property of the SelectionBase class in documentation. This property can be changed
since version 2.1 of library.
mvockerodt
Hello.
I appreciate the speed at which you guys respond to these queries. It's very much appreciated.
Regarding your comments:
This is just a zoom factor. There is still a lot of calculation involved to convert resolutions, calculate the required factor and then reposition the viewer etc. You already have the code to do this when the user clicks in the selected area. We just need a way of enabling that bit of code also execute when the mouse button goes up instead i.e. without requiring the 2nd click.
While on the subject, a ZoomSelection(Rectangle r) method might also be nice, where I can pass in a Rectangle (in screen or image coordinates?) and it'll try zoom to that rectangle. Again, that's based on that same code you already have for the ZoomSelection tool, but can be invoked completely programatically without using visual tools or me calculating zoom factors etc.
I assume you have methods to convert points and rectangles in screen coordinates (pixels) to/from image coordinates (taking into account things such as the current AutoscrollPosition, Zoom and DPI's)...? Can you guys possibly expose some of these so we can do those mappings easily as well?
This fires each time the mouse moves while the button is still down, not when the mouse is released and the selection is thereby "fixed". Maybe just needs an event fired in the Mouse Up event where you'd presumably also be changing some status to stop the selection tracking.
I did try that: the debugger shows it's accepting the new Rectangle value but the selection in the viewer is still displaying the old rectangle (must I do something to make it "catch up"?). I also presume the idea is one should assign Rectangle.Empty to clear it completely?
Regards,
Martin
Hello Martin,
You can use the following code instead of ZoomSelection(Rectangle r) method:
ZoomSelection selection = imageViewer1.CurrentTool as ZoomSelection;
if (selection != null)
  selection.Rectangle = new Rectangle(100, 100, 50, 50);
  selection.Zoom();
Please give me an example how do you plan to use this.
Event occurs when selection rectangle is changed. Mouse Up event does not change selection rectangle.
What code do you use? Please try to use this:
SelectionBase selection = imageViewer1.CurrentTool as SelectionBase;
  selection.Rectangle = new Rectangle(100, 100, 200, 300);
Yes, selection will be cleared if you set value of the Rectangle property to Rectangle.Empty.
