Convert from VintaSoftImage to BitMap and vice versa
Posted: Tue Jul 12, 2011 8:41 pm
by davidng
Hi everyone,
I am new to this software & when converting to VintaSoftImaging V4.3, I encountered quite a few errors.
Existing V3 codes now giving me errors.
Common errors after V4.3 migration
Error 86 'Vintasoft.Imaging.VintasoftImage' does not contain a definition for 'SetResolution
Error 85 Cannot convert type 'System.Drawing.Bitmap' to 'Vintasoft.Imaging.VintasoftImage'
Error 90 Cannot implicitly convert type 'Vintasoft.Imaging.VintasoftImage' to 'System.Drawing.Image
Error 92 Argument '2': cannot convert from 'Vintasoft.Imaging.VintasoftImage' to 'System.Drawing.Image'
Error 94 The type or namespace name 'PrintImageEventDelegate' does not exist in the namespace 'Vintasoft.Imaging.Print' (are you missing an assembly reference?
Please provide suggestions to fix these issues?
Many thanks in advance for your help.
Re: Convert from VintaSoftImage to BitMap and vice versa
Posted: Fri Jul 22, 2011 8:23 pm
Hello David,
You need to use the Resolution property of the VintasoftImage class instead.
You need to use the VintasoftImage(Image,Boolean) constructor if you want to create VintasoftImage object from the Bitmap object.
You need to use the GetAsBitmap() method of the VintasoftImage class if you want to get Bitmap object from the VintasoftImage object.
Error 94 The type or namespace name 'PrintImageEventDelegate' does not exist in the namespace 'Vintasoft.Imaging.Print'...
Please see declaration of the PrintImage event of the ImagePrintDocument class in the documentation.
