Suppress print progress popup
IntegraHarlan
Post by IntegraHarlan »
I am using the AnnotatedPdfPrintDocument class to print pdf documents.
I have the option to print with a print dialog or print without the dialog.
When I print with out the printDialog, I do not want to display the print progress status popup that displays the page being printed.
Is there a way to disable this pop from showing?
Harlan
Re: Suppress print progress popup
Hi Harlan,
For suppressing the print progress popup you need to change the print controller in PDF print document:
annotatedPdfPrintDocument.PrintController = new System.Drawing.Printing.StandardPrintController();
IntegraHarlan
That works
Thanks for the quick reply
