Convert large text file to multi page pdf
IntegraHarlan
Post by IntegraHarlan »
I am trying to convert a large text file to a multipage pdf document.
I tried the code in this example https://www.vintasoft.com/docs/vsimagin ... ument.html.
This works fine for 1 page, but when the text file is large enough to be on multiple pages, the text is truncated.
I could probably use the Measurestring method to find out how size of the string and parse it to fit the pages. However, this is cumbersome and from experience, not very accurate.
I am hoping you have an easier way to do this.
Re: Convert large text file to multi page pdf
Hi Harlan,
Here is example that allows to convert large text file to a multipage PDF document:
/// Converts a text file to a PDF document.
/// <param name="sourceTextFilename">The filename of source text file.</param>
/// <param name="destPdfFilename">The filename of destination PDF document.</param>
public static void ConvertTextFileToPdfDocument(
    string sourceTextFilename,
    string destPdfFilename)
    // font name
    string fontName = "Arial";
    // font size, in points
    int fontSize = 12;
    // text padding, in points
    Vintasoft.Imaging.PaddingF textPadding = new Vintasoft.Imaging.PaddingF(30);
    // get text from text file
    string text = System.IO.File.ReadAllText(sourceTextFilename, System.Text.Encoding.UTF8);
    // set new line to '\n' character
    text = text.Replace("\r\n", "\n");
    text = text.Replace("\n\r", "\n");
    text = text.Replace("\r", "\n");
    // create PDF document
        new Vintasoft.Imaging.Pdf.PdfDocument(destPdfFilename, Vintasoft.Imaging.Pdf.PdfFormat.Pdf_14))
        Vintasoft.Imaging.Pdf.Tree.Fonts.PdfFont font;
        // find TTF font that should be used for drawing a text
        using (System.IO.Stream fontProgramStream =
            document.FontProgramsController.GetTrueTypeFontProgram(fontName))
            // create PDF font based on TTF font program
            font = document.FontManager.CreateCIDFontFromTrueTypeFont(fontProgramStream);
        do
            // create page of A4 size
            Vintasoft.Imaging.Pdf.Tree.PdfPage pdfPage =
                new Vintasoft.Imaging.Pdf.Tree.PdfPage(document,
                    Vintasoft.Imaging.ImageSize.FromPaperKind(Vintasoft.Imaging.PaperSizeKind.A4));
            // add page to the PDF document
            document.Pages.Add(pdfPage);
            // get PdfGraphics that is associated with PDF page
            using (Vintasoft.Imaging.Pdf.Drawing.PdfGraphics graphics =
                Vintasoft.Imaging.Pdf.Drawing.PdfGraphics.FromPage(pdfPage))
                // create a brush that should be used for drawing a text
                Vintasoft.Imaging.Pdf.Drawing.PdfBrush brush =
                    new Vintasoft.Imaging.Pdf.Drawing.PdfBrush(System.Drawing.Color.Black);
                // specify a rectangle where text should be drawn
                System.Drawing.RectangleF rect = pdfPage.MediaBox;
                // apply padding
                rect = textPadding.ApplyTo(rect);
                // specify a string format that should be used for drawing a text
                System.Drawing.StringFormat stringFormat = System.Drawing.StringFormat.GenericDefault;
                // get text that must be drawn on current page
                string drawnText = GetDrawnText(graphics, font, fontSize, rect.Width, rect.Height, ref text);
                // draw text on the PDF page
                graphics.DrawString(drawnText, font, fontSize, brush, rect, Vintasoft.Imaging.Pdf.Drawing.PdfContentAlignment.Left, true);
        } while (!string.IsNullOrEmpty(text));
        // subset font
        document.FontManager.PackAllFonts();
        // pack PDF document
        document.Pack();
/// Returns the text portion that must be drawn on specified PDF graphics in rectange with specified size.
/// <param name="graphics">The PDF graphics.</param>
/// <param name="font">The text font.</param>
/// <param name="fontSize">The text font size.</param>
/// <param name="width">The width of text rectangle.</param>
/// <param name="height">The height of text rectangle.</param>
/// <param name="text">The text.</param>
/// <returns>The text portion that must be drawn.</returns>
private static string GetDrawnText(
    Vintasoft.Imaging.Pdf.Drawing.PdfGraphics graphics,
    Vintasoft.Imaging.Pdf.Tree.Fonts.PdfFont font,
    float fontSize,
    float width,
    float height,
    ref string text)
    if (string.IsNullOrEmpty(text))
        text = "";
        return text;
    float step = text.Length;
    float position = text.Length;
    int prevTextLength = 0;
    string drawnText = text;
    int drawnTextLength = text.Length;
    // measure all text
    float currentWidth, currentHeight;
    graphics.MeasureString(text.Substring(0, drawnTextLength), font, fontSize, width, true, out currentWidth, out currentHeight);
    // if text height is greater than maximum height
    if (currentHeight > height)
        // find drawn text using bisection algorithm
        while (drawnTextLength != prevTextLength)
            step /= 2;
                position -= step;
                position += step;
            prevTextLength = drawnTextLength;
            drawnTextLength = (int)System.Math.Ceiling(position);
            drawnText = text.Substring(0, drawnTextLength).Trim();
            graphics.MeasureString(drawnText, font, fontSize, width, true, out currentWidth, out currentHeight);
        while (currentHeight > height)
            drawnTextLength--;
        // add last '\n' character to the drawn text
        if (drawnTextLength < text.Length && text[drawnTextLength] == '\n')
            drawnTextLength++;
        if (drawnTextLength == 0)
            drawnTextLength = 1;
            drawnText = text.Substring(0, 1);
    text = text.Substring(drawnTextLength);
    return drawnText;
IntegraHarlan
Thank you for the example. It gets me pretty close.
However when using text files with long text string with no spaces, the text is truncated at the right border of the page.
I think this is happening because the DrawString method will word wrap but not wrap on character.
I was able to get around this by using a System.Drawing font and using the DrawString method that takes a System.Drawing font and the StringFormat enum.
This worked well, except the text does not get added to the page TextRegion. I assume that the reason for this is that I am using a System.Drawing font.
Here is the code I used:
        /// <remarks>This CAN throw.</remarks>
        /// <param name="filePath">The full-path to the file to convert.</param>
        /// <returns>The full-path to the converted PDF.</returns>
        public static string ConvertTextFileToPDF(string filePath)
            	// Path to the created PDF file.
            	string outputPath = string.Concat(filePath, ".pdf");
		//Get text from text file
		string text = File.ReadAllText(filePath, System.Text.Encoding.UTF8);
		// Set new line to '\n' character
		// Create PDF document
		using (PdfDocument pdfDocument = new PdfDocument())
			do
				float textMargin = 25f;
				PdfPage pdfPage = new PdfPage(pdfDocument, Vintasoft.Imaging.ImageSize.FromPaperKind(Vintasoft.Imaging.PaperSizeKind.Letter));
				// Add page to the PDF document
				pdfDocument.Pages.Add(pdfPage);
				// The DrawString method will not wrap on character when a PDF font is used. Using a System mono space font
				// so the DrawString method will wrap on character. The 15.25 em-size is the closest size that emulates the font size we want.
				Font font = new Font(FontFamily.GenericMonospace, 15.25f, GraphicsUnit.Pixel);
				// Create a brush that should be used for drawing a text
				PdfBrush brush = new PdfBrush(Color.Black);
				// Create area on document to write the text to.
				Vintasoft.Imaging.PaddingF textPadding = new Vintasoft.Imaging.PaddingF(textMargin);
				RectangleF regionRect = pdfPage.TextRegion.Rectangle;
				regionRect = textPadding.ApplyTo(regionRect);
				// Convert unit size to Pixel size because measuring the text size is done in pixels.
				float pageWidthPixels = PdfPage.ConvertFromUserUnitsToUnitOfMeasure(rect.Width, Vintasoft.Imaging.UnitOfMeasure.Pixels);
				float pageHeightPixels = PdfPage.ConvertFromUserUnitsToUnitOfMeasure(rect.Height, Vintasoft.Imaging.UnitOfMeasure.Pixels);
				// Get PdfGraphics that is associated with PDF page
				using (PdfGraphics graphics = PdfGraphics.FromPage(pdfPage))
					// Get text that must be drawn on current page
					string drawnText = GetDrawnText(font, pageWidthPixels, pageHeightPixels, ref text);
					// Draw text on the PDF page
					graphics.DrawString(drawnText, font, brush, rect, StringFormat.GenericDefault);
			} while (string.IsNullOrEmpty(text) == false);
			pdfDocument.FontManager.PackAllFonts();
			//Pack the document. This will also save it to the outputPath.
			pdfDocument.Pack(outputPath);
            return outputPath;
        /// Returns the text portion that must be drawn in PDF graphics on the rectangle with specified size.
        /// <param name="pageWidth">The width of text rectangle.</param>
        /// <param name="pageHeight">The height of text rectangle.</param>
        private static string GetDrawnText(Font font, float pageWidth, float pageHeight, ref string text)
                text = "";
                return text;
            // Use System.Drawing.Graphics because it uses GDI+. This will more accurately measure the text length.
            using (Graphics graphics = Graphics.FromHwnd(IntPtr.Zero))
                graphics.PageUnit = GraphicsUnit.Pixel;
                SizeF textSize = graphics.MeasureString(text.Substring(0, drawnTextLength), font, new SizeF(pageWidth, 1500f), StringFormat.GenericDefault);
                // If text height is greater than maximum height
                if (textSize.Height > pageHeight)
                    // Find drawn text using bisection algorithm
                        step /= 2;
                            position -= step;
                            position += step;
                        // Get the adjusted text length and text to compare with the page height.
                        drawnTextLength = (int)Math.Ceiling(position);
                        textSize = graphics.MeasureString(drawnText, font, new SizeF(pageWidth, 1500f), StringFormat.GenericDefault);
                    // Fine tune text length to fit in to the page height.
                    while (textSize.Height > pageHeight)
                        drawnTextLength--;
                    // Add last '\n' character to the drawn text
                        drawnTextLength++;
            // Update the remaining text to determine if another page is created by caller.
            return drawnText;
I cannot parse the string and add new line characters to it because the our requirements are that no new line characters are to be added to the text.
Is there a way to use the Drawing method with a PDFFont that will wrap on character?
or
Is there a way to use the Draw method with a System.Drawing font that will add the text to the page TextRegion?
Here is a sample of test text I have been using. You can just copy and paste into a txt file. :
abcdefghijklmnopqrstuvwx1abcdefghijklmnopqrstuvwx2abcdefghijklmnopqrstuvwx3abcdefghijklmnopqrstuvwx4abcdefghijklmnopqrstuvwx5abcdefghijklmnopqrstuvwx6abcdefghijklmnopqrstuvwx7abcdefghijklmnopqrstuvwx8abcdefghijklmnopqrstuvwx9abcdefghijklmnopqrstuvw10ab255
abcdefghijklmnopqrstuvwx1abcdefghijklmnopqrstuvwx2abcdefghijklmnopqrstuvwx3abcdefghijklmnopqrstuvwx4abcdefghijklmnopqrstuvwx5abcdefghijklmnopqrstuvwx6abcdefghijklmnopqrstuvwx7abcdefghijklmnopqrstuvwx8abcdefghijklmnopqrstuvwx9abcdefghijklmnopqrstuvw10ab510
abcdefghijklmnopqrstuvwx1abcdefghijklmnopqrstuvwx2abcdefghijklmnopqrstuvwx3abcdefghijklmnopqrstuvwx4abcdefghijklmnopqrstuvwx5abcdefghijklmnopqrstuvwx6abcdefghijklmnopqrstuvwx7abcdefghijklmnopqrstuvwx8abcdefghijklmnopqrstuvwx9abcdefghijklmnopqrstuvw10ab765
abcdefghijklmnopqrstuvwx1abcdefghijklmnopqrstuvwx2abcdefghijklmnopqrstuvwx3abcdefghijklmnopqrstuvwx4abcdefghijklmnopqrstuvwx5abcdefghijklmnopqrstuvwx6abcdefghijklmnopqrstuvwx7abcdefghijklmnopqrstuvwx8abcdefghijklmnopqrstuvwx9abcdefghijklmnopqrstuvw10a1020
abcdefghijklmnopqrstuvwx1abcdefghijklmnopqrstuvwx2abcdefghijklmnopqrstuvwx3abcdefghijklmnopqrstuvwx4abcdefghijklmnopqrstuvwx5abcdefghijklmnopqrstuvwx6abcdefghijklmnopqrstuvwx7abcdefghijklmnopqrstuvwx8abcdefghijklmnopqrstuvwx9abcdefghijklmnopqrstuvw10a1275
abcdefghijklmnopqrstuvwx1abcdefghijklmnopqrstuvwx2abcdefghijklmnopqrstuvwx3abcdefghijklmnopqrstuvwx4abcdefghijklmnopqrstuvwx5abcdefghijklmnopqrstuvwx6abcdefghijklmnopqrstuvwx7abcdefghijklmnopqrstuvwx8abcdefghijklmnopqrstuvwx9abcdefghijklmnopqrstuvw10a1530
abcdefghijklmnopqrstuvwx1abcdefghijklmnopqrstuvwx2abcdefghijklmnopqrstuvwx3abcdefghijklmnopqrstuvwx4abcdefghijklmnopqrstuvwx5abcdefghijklmnopqrstuvwx6abcdefghijklmnopqrstuvwx7abcdefghijklmnopqrstuvwx8abcdefghijklmnopqrstuvwx9abcdefghijklmnopqrstuvw10a1785
Hi Harlan,
Thank you for information. We improved the code of example.
Here is new example that allows to convert large text file to a multipage PDF document:
    // font name
    int fontSize = 12;
        do
                // apply padding
        // subset font
        document.Pack();
/// Returns the text portion that can be drawn on specified PDF graphics in rectange with specified size.
/// <param name="maxWidth">The width of text rectangle.</param>
/// <param name="maxHeight">The height of text rectangle.</param>
/// <returns>The text portion that can be drawn in rectange.</returns>
    float fontSize,
    float maxWidth,
    float maxHeight,
    ref string text)
    float lineHeight = fontSize;
    System.Text.StringBuilder textToDraw = new System.Text.StringBuilder();
    float totalHeight = 0;
    string line = null;
    while (text != null || line != null)
        // if there is not text line to process
        if (line == null)
            // cut next line from source text
            line = CutTextPart(ref text, '\n');
        // add line to the result text
        textToDraw.Append(GetDrawnLine(graphics, font, fontSize, maxWidth, ref line));
        textToDraw.Append("\n");
        // increase height of result text
        totalHeight += lineHeight;
        // if height of result text is greater than rectangle height
        if (totalHeight + lineHeight > maxHeight)
            break;
    if (line != null)
        text = line + '\n' + text;
    return textToDraw.ToString();
/// Returns the line portion that must be drawn on specified PDF graphics in rectange with specified size.
/// <param name="line">The text line.</param>
private static string GetDrawnLine(
    float fontSize,
    float maxWidth,
    ref string line)
    string drawnLine = null;
    string word = null;
    while (line != null)
        // cut next word from line
        word = CutTextPart(ref line, ' ');
        // create next drawn line
        string nextDrawnLine;
        if (drawnLine != null)
            nextDrawnLine = drawnLine.ToString() + ' ' + word;
            nextDrawnLine = word;
        // measure next drawn line
        graphics.MeasureString(nextDrawnLine, font, fontSize, float.MaxValue, false, out currentWidth, out currentHeight);
        // if next draw line width greater than max width
        if (currentWidth > maxWidth)
            // if drawn line is empty
            if (drawnLine == null)
                // add part of word to drawn line
                drawnLine = word;
                word = "";
                do
                    word = drawnLine.Substring(drawnLine.Length - 1) + word;
                    drawnLine = drawnLine.Substring(0, drawnLine.Length - 1);
                    graphics.MeasureString(drawnLine.ToString(), font, fontSize, float.MaxValue, false, out currentWidth, out currentHeight);
                while (currentWidth > maxWidth);
            break;
            drawnLine += ' ';
        drawnLine += word;
        word = null;
    if (word != null)
        line = word + ' ' + line;
    return drawnLine;
/// Cuts a text part from text start to the specified separator.
/// <param name="text">The source text.</param>
/// <param name="separator">The separator.</param>
/// <returns>The result text.</returns>
private static string CutTextPart(ref string text, char separator)
    int newLineIndex = text.IndexOf(separator);
    string result;
    if (newLineIndex < 0)
        result = text;
        text = null;
        return result;
    result = text.Substring(0, newLineIndex);
    if (newLineIndex == text.Length - 1)
        text = null;
        text = text.Substring(newLineIndex + 1);
    return result;
IntegraHarlan
Thank you for your reply.
This example works well except that it adds new line characters to the end of each line which does not meet our requirements.
Our product management has agreed to update the requirements. to allow adding new line characters to the end of each line.
However, If it would be a nice feature to be able to convert text files to pdf that will wrap on characters with out adding new line characters.
Thanks.
Hi Harlan,
Thank you for your comment.
Starting from VintaSoft Imaging .NET SDK 10.1 your task can be solved by another much easier way.
Here are steps, which must be done:
  • Create DOCX document, which will be used as a template for text content:
    • Create empty DOCX document in MS Word.
    • Add paragraph to the document.
    • Add text "[TextContent]" to the paragraph.
    • Save the document.
  • In your application:
This way is much easier because you can prepare template DOCX document with any formatting in paragraph. After this all task will be done by DOCX renderer.
IntegraHarlan
Alex, thank you for the information on using a docx document.
I did notice that when converting a docx to pdf, the hyperlinks are no longer function after converting to a pdf.
is there a way to make hyper links functional when the docx is converted to pdf?
Hi Harlan,
IntegraHarlan wrote: Fri Jun 25, 2021 7:34 pm I did notice that when converting a docx to pdf, the hyperlinks are no longer function after converting to a pdf.
Hyperlinks should work correctly if you convert DOCX document to a PDF document.
Please do the following test:
  • Run VintaSoft Document Viewer Demo ("[SdkInstallPath]\VintaSoft\Imaging .NET v10.1\Bin\DotNet4\AnyCPU\DocumentViewerDemo.exe").
  • Open DOCX document with hyperlinks.
  • Select "File => Save As..." menu and save document to a PDF file.
  • Open saved PDF file in VintaSoft Document Viewer Demo or Adobe Reader and test hyperlinks - they should work correctly.
Let me know results of your test.
IntegraHarlan
Thank you for pointing me to the demo. I have the documents converting to pdf's with the annotations working now.
