WinForms: Load a TIFF image into an image viewer and PictureBox.
This topic contains C# code snippet that shows how to load a TIFF image into an image viewer and PictureBox.
using System;
using System.Drawing;
using System.Windows.Forms;
using Vintasoft.Imaging;
using Vintasoft.Imaging.UI;
namespace WindowsFormsApplication1
    /// Main form.
    public partial class MainForm : Form
        /// Initializes a new instance of the <see cref="MainForm"/> class.
        public MainForm()
            InitializeComponent();
            thumbnailViewer.FocusedIndexChanged +=
                new EventHandler<FocusedIndexChangedEventArgs>(thumbnailViewer_FocusedIndexChanged);
            pictureBox.SizeMode = PictureBoxSizeMode.Zoom;
        /// Clears image collection of thumbnail viewer and
        /// adds image(s) to an image collection of thumbnail viewer.
        private void openButton_Click(object sender, EventArgs e)
            if (openFileDialog.ShowDialog() == DialogResult.OK)
                thumbnailViewer.Images.ClearAndDisposeItems();
                    thumbnailViewer.Images.Add(openFileDialog.FileName);
                catch (Exception exc)
                    MessageBox.Show(exc.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
        /// Image is loaded in the thumbnail viewer.
        private void thumbnailViewer_FocusedIndexChanged(
            object sender,
            FocusedIndexChangedEventArgs e)
            ThumbnailViewer viewer = (ThumbnailViewer)sender;
            VintasoftImage image = null;
            if (e.FocusedIndex != -1)
                image = viewer.Images[e.FocusedIndex];
            ShowImageInImageViewer(image);
            ShowImageInPictureBox(image);
        /// Shows the image in ImageViewer.
        /// <param name="image">The image.</param>
        private void ShowImageInImageViewer(VintasoftImage image)
            imageViewer.Image = image;
        /// Shows the image in PictureBox.
        private void ShowImageInPictureBox(VintasoftImage image)
            Image newBitmap = null;
                if (image != null)
                    // create bitmap
                    newBitmap = image.GetAsBitmap();
            catch
            // get the previous bitmap
            Image previousBitmap = pictureBox.Image;
            // load new bitmap in PictureBox
            pictureBox.Image = newBitmap;
            // if previous bitmap exists
            if (previousBitmap != null)
                // dispose the previous bitmap
                previousBitmap.Dispose();
        /// Raises the Closed event.
            ShowImageInImageViewer(null);
            ShowImageInPictureBox(null);
            base.OnClosed(e);
Source codes of WinForms application for VintaSoft Imaging .NET SDK 14.0 can be downloaded here.
