update the version
Mahamat
update the version
Post by Mahamat » Fri Oct 13, 2017 4:22 am
Hi
after i update to the latest ver 10.2,x by referencing the new dll i start getting this message
An unhandled exception of type 'System.BadImageFormatException' occurred in ECM_Archiveo.exe
Additional information: Could not load file or assembly 'Vintasoft.Twain, Version=10.2.3.1, Culture=neutral, PublicKeyToken=153caf29a10d2e31' or one of its dependencies. An attempt was made to load a program with an incorrect format.
any idea what might be the solution
thank you
Re: update the version
Post by Alex » Fri Oct 13, 2017 9:26 am
Hi Mahamat,
The System.BadImageFormatException means that you are compiling your application in one format but the referenced DLLs have another format. Please make sure that you are using Vintasoft.Twain.dll compiled in AnyCPU (x86, x64) mode if you are compiling your application in AnyCPU (x86, x64) mode.
Mahamat
Post by Mahamat » Sat Oct 14, 2017 1:06 am
Thank you very much ,, you are 100% right.. my problem got solved
i was referencing the any cpu and adding the 64bit dll
