ActiveEx Registered Mode
bill.raymond
Post by bill.raymond »
Recently opurchased ActiveEx Control to use in MS Access and Javascript
2 problems
1 What is the syntax of the register command for MS Access?
2 When using javascript I have
uninstalled the evaluation control
modified my code to use the Register Method
However the control continues to act in evaluation mode
What more do I need to do?
Bill
Re: ActiveEx Registered Mode
Hello Bill,
When using javascript I have uninstalled the evaluation control modified my code to use the Register Method However the control continues to act in evaluation mode What more do I need to do?
You need the Single Developer or Site license for usage of VintaSoftTwain ActiveX in MS Access.
You need the Server license for usage of VintaSoftTwain ActiveX in JavaScript (web application).
Please read the license for more info: http://www.vintasoft.com/vstwain-license.html
Please contact support at support@vintasoft.com or http://www.vintasoft.com/support.php with questions about licensing and registration of the product.
