using System;
using System.Drawing;
using System.Windows.Forms;
using Vintasoft.Imaging;
using Vintasoft.Imaging.UI;
namespace WindowsFormsApplication1
/// Main form.
public partial class MainForm : Form
/// Initializes a new instance of the <see cref="MainForm"/> class.
public MainForm()
InitializeComponent();
thumbnailViewer.FocusedIndexChanged +=
new EventHandler<FocusedIndexChangedEventArgs>(thumbnailViewer_FocusedIndexChanged);
pictureBox.SizeMode = PictureBoxSizeMode.Zoom;
/// Clears image collection of thumbnail viewer and
/// adds image(s) to an image collection of thumbnail viewer.
private void openButton_Click(object sender, EventArgs e)
if (openFileDialog.ShowDialog() == DialogResult.OK)
thumbnailViewer.Images.ClearAndDisposeItems();
thumbnailViewer.Images.Add(openFileDialog.FileName);
catch (Exception exc)
MessageBox.Show(exc.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
/// Image is loaded in the thumbnail viewer.
private void thumbnailViewer_FocusedIndexChanged(
object sender,
FocusedIndexChangedEventArgs e)
ThumbnailViewer viewer = (ThumbnailViewer)sender;
VintasoftImage image = null;
if (e.FocusedIndex != -1)
image = viewer.Images[e.FocusedIndex];
ShowImageInImageViewer(image);
ShowImageInPictureBox(image);
/// Shows the image in ImageViewer.
/// <param name="image">The image.</param>
private void ShowImageInImageViewer(VintasoftImage image)
imageViewer.Image = image;
/// Shows the image in PictureBox.
private void ShowImageInPictureBox(VintasoftImage image)
Image newBitmap = null;
if (image != null)
// create bitmap
newBitmap = image.GetAsBitmap();
catch
// get the previous bitmap
Image previousBitmap = pictureBox.Image;
// load new bitmap in PictureBox
pictureBox.Image = newBitmap;
// if previous bitmap exists
if (previousBitmap != null)
// dispose the previous bitmap
previousBitmap.Dispose();
/// Raises the Closed event.
ShowImageInImageViewer(null);
ShowImageInPictureBox(null);
base.OnClosed(e);
Source codes of WinForms application for VintaSoft Imaging .NET SDK 10 can be downloaded here.
