For doing our task we need:
- Open Visual Studio .NET 2019.
- Create an ASP.NET MVC 5 application project.
- Add the references to the Vintasoft assemblies (version 10.x.x.x) and Vintasoft JavaScript files to the project:
- Vintasoft.Shared.dll
- Vintasoft.Shared.Web.dll
- Vintasoft.Imaging.dll
- Vintasoft.Imaging.Web.Services.dll
- Vintasoft.Imaging.Web.Api2Controllers.dll
- Scripts\Vintasoft\Vintasoft.Shared.js
- Scripts\Vintasoft\Vintasoft.Imaging.Html5.js
- Create a web service, which will get image from database and render image tile or thumbnail for web image viewer.
- Create a Web API 2 controller with name VintasoftDBImageApiController. Controller will be used for rendering of images and thumbnails.
- Create the DataBaseImageStorage class, which will be used as a storage for images in database.
- Create the DatabaseEmulator class, which will be used for emulating connection with database.
- Specify that VintasoftDBImageApiController class must use DataBaseImageStorage class as a data storage for images.
- Create a default web view.
- Add HTML5 web image viewer to the web view.
- Create 3 web images, which are linked with images stored in database.
- Create 3 buttons. Each button allows to load image in web image viewer.
Source codes of ASP.NET MVC 5 application for VintaSoft Imaging .NET SDK 10 can be downloaded from here.
