Barcode PDF417 error
Posted: Tue Dec 10, 2019 10:29 am
Recently I have trouble generating barcode pdf417 using the barcodewriter.settings.ValueItems property the output bitmap gives error:
Unexpected symbol '' (0x001E).
The string I am passing has data: "[)>01029922384001C00000110001598EMSYAC2011/12LBNABCMIAMIFLABC ABC063Z0111ZABC ABC12Z404509699514ZABC15Z3006021Z022Z023Z1234567824Z09K7890"
OR
"[)>\u001e01\u001e0299223\u001d840\u001d01\u001dC00000110001598\u001dEMSY\u001dAC\u001d201\u001d\u001d1/1\u001d2LB\u001dN\u001dABC\u001dMIAMI\u001dFL\u001dABC ABC\u001d\u001d06\u001d3Z01\u001d11ZABC ABC12Z4045096995\u001d14ZABC\u001d15Z30060\u001d21Z0\u001d22Z0\u001d23Z1234567824Z09K7890\u001d\u001e\u0004"
As I know the above barcodewriter.settings.ValueItems property takes array of Numeric, Text, Binary which is failing.
But the other property [barcodeWriter.Settings.Value] working fine.
could you help in the issue as I am new to using this api set.
OR
