Version 10.1 of VintaSoft Imaging .NET SDK has been released.
Posted: Wed Jun 23, 2021 10:29 am
				We are proud to announce the release of new major version 10.1 of VintaSoft Imaging .NET SDK and the related Annotation, PDF,
JBIG2, JPEG2000, Document Cleanup, OCR, DICOM, Forms Processing and Office Plug-ins.
What's new in VintaSoft Imaging .NET SDK 10.1:
What's new in VintaSoft Office .NET Plug-in 2.1:
What's new in VintaSoft PDF .NET Plug-in 7.1:
What's new in VintaSoft Annotation .NET Plug-in 10.1:
- .NET development
- Added the ability to render WMF images in vector form.
 - Web development
- Supported platforms:
- JavaScript engine does not depend on jQuery library anymore and it is now fully written in JavaScript ES5.
 - JavaScript engine now supports only HTML5 web browsers. Discontinued the support for old browsers. Discontinued the support of Vintasoft.Imaging.Svg.js file.
 - JavaScript dialogs are moved from Vintasoft.Imaging.DocumentViewer.js file to Vintasoft.Imaging.DocumentViewer.Dialogs.Simple.js file.
 - jQuery dialogs are moved from Vintasoft.Imaging.DocumentViewer.js file to Vintasoft.Imaging.DocumentViewer.Dialogs.jQueryUI.js file.
 - Added minor changes into JavaScript API. Detailed information about API changes is available here: https://www.vintasoft.com/docs/vsimaging-dotnet-web/Programming-Imaging_Web-Api_Changes_History-v10_1_Imaging.html
 - Fixed non-critical bugs in JavaScript engine.
 - Demo applications:
- All Angular demo applications now use Angular dialogs only. Previously some Angular demo applications used jQuery dialogs from Vintasoft.Imaging.DocumentViewer.js file.
 - Improved the code of ASP.NET MVC demo applications.
 - Improved the code of ASP.NET WebForms demo applications.
- .NET development
- Added the ability to edit existing DOCX and XLSX documents:
- open an existing DOCX/XLSX document
 - find, delete, replace text, change text properties (background color, text color, bold text, font, text size, etc)
 - copy, insert, change and delete an image (barcode image)
 - copy, insert, change and delete a row in a table
 - change a value of table cell, change a color of table cell
 - change table borders
 - save the changed document to a DOCX/XLSX file
 - export the changed document to a file format, which is supported by VintaSoft Imaging .NET SDK (PDF, PDF/A, TIFF, etc)
 - Significantly improved the algorithms, which render DOCX documents:
- Added the ability to render footnotes and endnotes.
 - Added the support for calculated fields (DATE, TIME, SAVEDATE, CREATEDATE, PRINTDATE, MACROBUTTON, NUMPAGES, FORMCHECKBOX, TOC, PAGEREF, HYPERLINK, STYLEREF, PAGE).
 - Added the support for deleted content.
 - Added the ability to render the page background.
 - Added the interpretation of "Repeat as header row at the top of each page" flag for table row.
 - Implemented the algorithm of autosizing table cells by content.
 - Improved the support for floating elements.
 - Improved the support for VML objects.
 - Improved the algorithm that layouts text paragraphs.
 - Improved the algorithm that selects a font for text.
 - Improved the algorithm that draws CJK text (Chinese, Japanese, Korean).
 - Improved the algorithm that determines the line spacing between text lines.
 - Improved the word wrapping algorithm of text line
 - Improved the algorithm that aligns text.
 - Improved the algorithm of tab stops calculation in text.
 - Improved the algorithm that numerates a content on page.
 - Improved the algorithm that interprets the "Line and Page Breaks" flag.
 - Improved the algorithm that interprets the "Keep paragraphs together" flag.
 - Improved the algorithm that calculates the page break.
 - Improved the algorithm that draws tables.
 - Improved the algorithm that layouts header and footer on page.
 - Improved the algorithm that draws lists on page.
 - Improved the algorithm that draws graphics on page.
 - Improved the algorithm that draws WMF images.
 - Improved the algorithms, which render XLSX documents:
- Added the support for cell formatting using the financial style.
 - Improved the word wrapping algorithm of text line.
 - Fixed many bugs in algorithms, which render DOCX and XLSX documents.
- Created new WinForms demo application - ReportGeneratorDemo, which demostrates how to generate reports based on DOCX or XLSX document templates.
- .NET development
- Added the support for Text-Markup annotations (Highlight, Underline, Strikeout).
 - Web development
 - JavaScript engine now supports only HTML5 web browsers. Discontinued the support of old browsers. Discontinued the support of Vintasoft.Imaging.Pdf.Svg.js file.
 - Added minor changes in JavaScript API. Detailed information about API changes is available here: https://www.vintasoft.com/docs/vsimaging-dotnet-web/Programming-Imaging_Web-Api_Changes_History-v10_1_Pdf.html
- Web development
 - JavaScript engine now supports only HTML5 web browsers. Discontinued the support of old browsers. Discontinued the support of Vintasoft.Imaging.Annotation.Svg.js file.
 - Added minor changes in JavaScript API. Detailed information about API changes is available here: https://www.vintasoft.com/docs/vsimaging-dotnet-web/Programming-Imaging_Web-Api_Changes_History-v10_1_Annotation.html
