Close polygon when finished
missionRoom
Post by missionRoom »
Is there a way to close a polygon when the user finishes building it, if it's not already closed?
Re: Close polygon when finished
If you want to create polygon, I suggest you to use Polygon annotation (not Freehand annotation).
If you are using Freehand annotation and you want to create closed polygone, you need to modify list of annotation points, which is accessible using Points property.
