Hello
Does it possible programmatically select some annotation? Like performClick at Button.
Thanks!
AnnotationViewer
Yuri
Re: AnnotationViewer
Yes, what problem did you encounter?
R_Kranj
I solved this problem with one annotation.
But, how can I make multiselect?
Is it possible multiselect?
Yuri
Unfortunately multiselection for annotations is not supported at this time.
I will submit your suggestion to VintaSoft development department. Thanks.
R_Kranj
Support multiselection would be great.
And another question:
I have some annonce in invisible area. Zoom is 500%.
I select it programaticaly but annonce remains out of visible area.
Is it possible automatically scroll to right position. How?
Thanks.
Thanks.
Yuri
You should calculate the coordinates and use ImageViewer.AutoScrollPosition Property
to place the screen in an area of image you need.
R_Kranj
I have another question/problem;
Is it possible to show magnifier programatically without mouse click? How?
I need show two magnifiers on two forms in the same time.
Is it possible change location of magnifier?
Thanks!
Thanks!
Magnifier class has the Show() and Hide() methods. You should set mouse position in ImageViewer and call the Magnifier.Show() method if you want to show magnifier.
