Get an individual pagesize from a multipage tiff
philip.y
Post by philip.y »
Hi
Is it possible to obtain the page size (in bytes) of individual pages in a tiff file?
I'm wanting to determine the collective size of all colour pages within a tiff, ignoring non-colour so was looking to do something like:
Using tif As New Vintasoft.Imaging.Codecs.Tiff.TiffFile(sourceFile)
                For Each page In tif.Pages
                    If (page.BitsPerPixel) >= 24 Then
                        lColourSize = lColourSize + page.Length
                Next
            End Using
"page.length" always returns zero. Is there a way to do this without copying the page out?
Cheers
Phil
Re: Get an individual pagesize from a multipage tiff
Hi Phil,
Length, in bytes, of TIFF image data can be calcuated from TIFF image metadata.
Here is an example that shows how to get length, in bytes, of TIFF image data:
using System;
using Vintasoft.Imaging.Codecs.ImageFiles.Tiff;
namespace ConsoleApplication1
    class Program
            Console.WriteLine(string.Format("'strips.tif', page 0, image data length in bytes: {0}", GetTiffImageDataLengthInBytes("strips.tif", 0)));
            Console.WriteLine(string.Format("'tiles.tif', page 0, image data length in bytes: {0}", GetTiffImageDataLengthInBytes("tiles.tif", 0)));
            Console.WriteLine("Press any key...");
            Console.ReadKey();
        /// Gets the length, in bytes, of TIFF image data.
        /// <param name="filename">Name of TIFF file.</param>
        /// <param name="pageIndex">Zero-based index of page in TIFF file.</param>
        /// <returns></returns>
        static uint GetTiffImageDataLengthInBytes(string filename, int pageIndex)
            // length, in bytes, of image data
            uint imageDataLengthInBytes = 0;
            // open TIFF file
            using (TiffFile tiffFile = new TiffFile(filename))
                // get TIFF tag collection of specified TIFF page
                TiffTagCollection tags = tiffFile.Pages[pageIndex].IFD.Tags;
                // get StripByteCounts tag
                TiffTag stripByteCountsTag = tags.Find(TiffTagId.StripByteCounts);
                // if tag is found image data are stored in strips
                if (stripByteCountsTag != null)
                    object stripByteCountsTagData = stripByteCountsTag.Data;
                    uint[] stripByteCountTagAsUIntArray = stripByteCountsTagData as uint[];
                    if (stripByteCountTagAsUIntArray != null)
                        for (int i = 0; i < stripByteCountTagAsUIntArray.Length; i++)
                            imageDataLengthInBytes = stripByteCountTagAsUIntArray[i];
                // get TileByteCounts tag
                TiffTag tileByteCountsTag = tags.Find(TiffTagId.TileByteCounts);
                // if tag is found image data are stored in tiles
                if (tileByteCountsTag != null)
                    object tileByteCountsTagData = tileByteCountsTag.Data;
                    uint[] tileByteCountsTagAsUIntArray = tileByteCountsTagData as uint[];
                    if (tileByteCountsTagAsUIntArray != null)
                        for (int i = 0; i < tileByteCountsTagAsUIntArray.Length; i++)
                            imageDataLengthInBytes = tileByteCountsTagAsUIntArray[i];
            return imageDataLengthInBytes;
philip.y
Post by philip.y »
That's exactly what I needed!
Thanks (as always) for your reply.
