Draw RulerAnnotation from PointF(0,0) to PointF(500, 0)
markdhem
Post by markdhem »
Hi Alex
I want to draw on a AnnotationViewer a
RulerAnnotation from PointF(0,0) to PointF(500,0) programmatically.
Best Regards
Mark
Re: Draw RulerAnnotation from PointF(0,0) to PointF(500, 0)
Hi Mark,
You can set the start point of ruler annotation (line-based annotation) using the LineAnnotationData.StartPoint property:
https://www.vintasoft.com/docs/vsimagin ... Point.html
You can set the end point of ruler annotation (line-based annotation) using the LineAnnotationData.EndPoint property:
Please read about the annotation's coordinate system and units of measure here:
https://www.vintasoft.com/docs/vsimagin ... _Data.html
markdhem
Post by markdhem »
I read the documentation but still I don't get it, can you show me an example or a hint about this?
Best regards
Mark
Here is code snippet that shows how to add the ruler annotation with coordinates (0;0)-(0;500) to the image in annotation viewer:
// create an image
Vintasoft.Imaging.VintasoftImage image = new Vintasoft.Imaging.VintasoftImage(1000, 1000);
// add the image to the annotation viewer
annotationViewer1.Images.Add(image);
// create the ruler annotation
Vintasoft.Imaging.Annotation.RulerAnnotationData rulerAnnotationData = new Vintasoft.Imaging.Annotation.RulerAnnotationData();
// coordinate in pixels
float coordinateInPixels = 500;
// coordinate in DIP (device independent pixels)
float coordinateInDips = coordinateInPixels * 96 / image.Resolution.Horizontal;
// set the ruler coordinates
rulerAnnotationData.StartPoint = new System.Drawing.PointF(0, 0);
rulerAnnotationData.EndPoint = new System.Drawing.PointF(0, coordinateInDips);
// add the ruler annotation to the image in annotation viewer
int imageIndex = 0;
annotationViewer1.AnnotationDataController[imageIndex].Add(rulerAnnotationData);
markdhem
Post by markdhem »
This works perfectly. Thanks a lot, but I still have a problem, when I have a multiple pages and when I go to the
second page and click the button it will draw at page 1.
Mark
You need to set the correct image index when you selecting the annotation collection:
int imageIndex = 0;
markdhem
Post by markdhem »
I still don't know how to select the Current Page.
Please give me an example. Thank you
Mark
Hello Mark,
The focused image in image viewer can be changed using the ImageViewer.FocusedIndex property:
https://www.vintasoft.com/docs/vsimagin ... Index.html
More info about image viewer please read here:
https://www.vintasoft.com/docs/vsimagin ... Forms.html
