Reading GS1 Info1D
tiagolpt
Reading GS1 Info1D
Post by tiagolpt »
Hello guys,
i've been using the software to read barcode from given images,
when using reader demo program i've been able to see information about the narrow bar count and narrow bar size..
to acess this info in code im doing the follow:
IBarcodeInfo[] infos = reader.ReadBarcodes(barcodeImage);
for (int i = 0; i < infos.Length; i++)
    IBarcodeInfo info = infos[i];
    var info1d = info as BarcodeInfo1D;
if i use a GS1-128 the cast returns null, however I can see on the private properties of that object that in fact it contains those two properties (narrow bar count and narrow bar size), the strange thing is, if i remove the subset of GS1-128 from the settings the cast works..
How can i access those two properties without the cast?
In the reader demo those properties are always available.
Re: Reading GS1 Info1D
Please use the "info.GetType()" method for getting information about instance type and cast the instance to the correct type.
DarkStar
Post by DarkStar »
Hello!
Use this code:
    if (info is BarcodeSubsetInfo)
       info = ((BarcodeSubsetInfo)info).BaseBarcodeInfo;
