We are using DropShadowEffect for Wpf annotation views (WpfAnnotationView). All effects are visible in the annotation viewer. Is there anyway to burn annotations with DropShadowEffect onto image?
Babu
DropShadowEffect for WPF Annotation Views
Yuri
Re: DropShadowEffect for WPF Annotation Views
Provide please a snippet of your code showing how you are adding the effect.
Regards,
Yuri
Regards,
Yuri
gpbabu
Hello Yuri,
Please see the code. In Annotation viewer, annotation displays properly with a shadow. However, when it is burnt, it does not include the effect.
Babu
Babu
// Set dropshadow effect for the annotation view.
rectangleAnnotationView.Effect = new DropShadowEffect
ShadowDepth = 1,
BlurRadius = 5,
Direction = 270,
Color = Color.FromArgb(255, 204, 204, 204),
Hello Babu,
Please try to use the RectangleAnnotationData.ShadowBrush property:
https://www.vintasoft.com/docs/vsimagin ... Brush.html
gpbabu
We tried it. Rectangle with transparent fill color causes background shadow cover the fill area instead of showing the shadow for the outline. Also, it does not have a blur effect and only shows hard shadows. You may want to consider supporting in the product as it provides rich feature set for Vintasoft WPF controls.
Babu
Babu
Hi Babu,
Please send us (to support@vintasoft.com) a simple working project, which shows the shadow effect you want to have. We will analyze your code and will try to provide you the best solution for your task.
gpbabu
Thanks Alex. We found an approach to burn annotations with effects by setting drawing visual effect to annotation view effect. It works very well. We could get all WPF effects into exported image.
Regards
Babu
Regards
Babu
