How can I use document viewer as partial view
Johnsnow
Post by Johnsnow »
I am exploring the source codes of VintaSoft ASP.NET Annotation Demo in installation of VintaSoft Imaging NET SDK - function __initMenu in file "[SdkInstallPath]\VintaSoft\Imaging .NET v11.0\Examples\ASP.NET MVC\CSharp\AspNetMvcAnnotationDemo\Scripts\AnnotationDemo.js".
// register new UI elements
    __registerNewUiElements();
    // create the document viewer settings
    var docViewerSettings = new Vintasoft.Imaging.DocumentViewer.WebDocumentViewerSettingsJS("documentViewerContainer", { annotations: true });
    // initialize main menu of document viewer
    __initMenu(docViewerSettings);
    // initialize side panel of document viewer
    __initSidePanel(docViewerSettings);
    // initialize image viewer panel of document viewer
    __initImageViewerPanel(docViewerSettings);
    _docViewer = new Vintasoft.Imaging.DocumentViewer.WebDocumentViewerJS(docViewerSettings);
in html its
<div id="documentViewerContainer"></div>
Now, I want to make partial view of this document viewer, to use that either in multiple pages or multiple times on same pages, So can you advise for the same?
Re: How can I use document viewer as partial view
Hi John,
If you want to use multiple instances of VintaSoft web document viewer, you need to:
  • Create container for each instance of document viewer:
    <div id="documentViewerContainer1"></div>
    <div id="documentViewerContainer2"></div>
  • Create separate JavaScript instances for each document viewer:
    var docViewerSettings1 = new Vintasoft.Imaging.DocumentViewer.WebDocumentViewerSettingsJS("documentViewerContainer1", { annotations: true });
    var docViewer1 = new Vintasoft.Imaging.DocumentViewer.WebDocumentViewerJS(docViewerSettings1);
    var docViewerSettings2 = new Vintasoft.Imaging.DocumentViewer.WebDocumentViewerSettingsJS("documentViewerContainer2", { annotations: true });
    var docViewer2 = new Vintasoft.Imaging.DocumentViewer.WebDocumentViewerJS(docViewerSettings1);
