an important issue for my project is to set and get image addesses of scanner Kodeak i5850. With following code:
Dim kodakImageAddressEnabledCap As Vintasoft.Twain.DeviceCapability = device.Capabilities.Find(CUShort(Vintasoft.Twain.KodakDeviceCapabilityId.Kodak_ImageAddressEnabled))
I get "nothing" for kodakImageAddressEnabledCap
The example, I found:
Dim kodakUltrasonicDetectionCap As Vintasoft.Twain.DeviceCapability = device.Capabilities.Find(CUShort(Vintasoft.Twain.KodakDeviceCapabilityId.Kodak_UltrasonicSensitivity))
I get a value for kodakUltrasonicDetectionCap -> "{Id=32807, Name=Kodak_UltrasonicSensitivity}"
Would it be possible to give me a hint, how get access to the image address in order to set it by CAP. Thank you.
Sincerely, Hans
Hans7711
Re: KodakDeviceCapabilityId.Kodak_ImageAddressEnabled
Hi Hans,
You can get a list of capabilities, which are supported by TWAIN device, using the Device.Capabilities property.
Please check if Kodak_ImageAddressEnabled (0x8016) capability is supported by your Kodak scanner.
