could you tell me if your plugin has a way (when scanning from ADF or not) to ask if there are more papers to scan?
If I red properly, it has something to do with WebAcquireModalStateEnumJS, but i was not able to find a function or a method in your Documentation to help me understand it or doing it.
Thank you .
Luigi
Which method to make the device asking for more document to scan?
Re: Which method to make the device asking for more document to scan?
Hi Luigi,
You can set count of images to scan using the WebTwainDeviceJS.set_XferCount function.
0 means that TWAIN scanner should scan all images from document feeder, 1 means that TWAIN scanner should scan 1 image, 2 means that TWAIN scanner should scan 2 images, etc.
Best regards, Alexanader
Do you mean that if for example i set the count to 2, after two papers it asks for more? Or it stops to scan?
When i set twainDevice.open(true, true), in the UI dialog of the scanner there is a checkbox telling the device to ask if there are more papers to scan.
I want to achieve the same result without showing the UI.
Thank you,
Luigi
Thank you,
Luigi
If you set XferCount to 2, TWAIN scanner will acquire 2 images and will stop image scanning.
If you want to ask more paper when feeder is empty, you can go by the following way:
- Set XferCount to 0 and start image scanning => TWAIN scanner will process all pages in document feeder.
- Ask for more pages.
- Start new image scanning process if user added pages to the document feeder.
Sorry Alex,
maybe i'm too dumb, but how can i ask for more pages? Is there a specifc method for do this?
Wht i would achieve is this:
1 Step : Start scanning whatever the source is :ADF or Flatbed.
2 Step : Once finished the 1 Step, prompt a dialog : "End the scanning here or load more papers and continue?"
Right now the XferCount is set to 0 by default and scanning goes on till the feeder is empty, does not ask for more, closes it and sends the file to an ftp server as i set it. The same is for the Flatbed.
I've tried to add a 3rd Case(where i set acquireModalState = 2) to the Do While of acquireModalState to ask for more paper to be fed and on confirm, restart the loop from beginning. The problem is that, got on the 3rd case, the loop won't begin again and always reaches the acquireModalState == 0.
Do you have any method or way to handle the Do While of acquireModalState ?
-----------------------------------------------OR-------------------------------------------------------
Are there, in your plugin, built-in methods to achieve the Step 1 and 2 listed before ?
This is the last big issue i've to resolve before finishing my Web App and buy your license.
Luigi
Luigi
Hi Luigi,
You need to implement the following logic:
- Open TWAIN device.
- Acquire images from document feeder.
- Close TWAIN device.
- Ask user if he wants to continue scanning.
Using promises and global variable storage, i managed to get a dialog asking for more papers and to restart the scanning. Now the issue is about finishing the process on End Dialog's button. When the user presses it, i got an error :
here is my actual code :
Could you help me?
Thank you.
Best Regards,
Luigi
I suppose it's thrown by the self.acquiredImages.getAsBase64String() function, i think because everytime the user confirms for continuing scanning, it keeps the IDs but not the relative previous scanned images.Error: Image with identifier: 'bla bla bla' is not found
//Triggering the Scanning Process
self.managerDOM.find(".scan_btn").each(function () {
var item = $(this);
item.click(async function (e) {
var dateScan = self.getTime();
var nomeFile = item.text() + '_' + dateScan;
console.log(nomeFile)
self.scanMore = true;
self.acquiredImages = new Vintasoft.Twain.WebAcquiredImageCollectionJS(self.twainDeviceManager);
while (self.scanMore == true) await self.__synchronouslyAcquireImagesFromTwainScannerAndSaveToPdfFile(self.selectedDevice, nomeFile);
//Scanning Function
__synchronouslyAcquireImagesFromTwainScannerAndSaveToPdfFile(selectedDevice, nome_file) {
var self = this;
var twainDevice = selectedDevice;
return new Promise(async function (resolve, reject) {
try {
// open TWAIN device manager
self.twainDeviceManager.open(self.twainDeviceManagerInitSettingsJS);
// // get the default TWAIN device
// twainDevice = twainDeviceManager.get_DefaultDevice();
// open TWAIN device (display device UI and display dialog with image scanning progress)
twainDevice.open(false, true);
// specify that grayscale images must be acquired from TWAIN scanner
twainDevice.set_PixelType(new Vintasoft.Twain.WebPixelTypeEnumJS("Gray"));
// create collection for images acquired from TWAIN scanner
// var acquiredImages = new Vintasoft.Twain.WebAcquiredImageCollectionJS(self.twainDeviceManager);
var acquireModalState;
//var savedImageCount = 0;
do {
// do one step of modal image acquisition process
var acquireModalResult = twainDevice.acquireModalSync();
l(acquireModalResult);
// get state of image acquisition
acquireModalState = acquireModalResult.get_AcquireModalState().valueOf();
l('acquiremodalstate');
l(acquireModalState);
switch (acquireModalState) {
case 2: // image is acquired
// get acquired image
var acquiredImage = acquireModalResult.get_AcquiredImage();
// add acquired image to the collection of acquired images
self.acquiredImages.add(acquiredImage);
// save acquired image to "result.pdf" file
console.log(self.acquiredImages);
break;
case 4: // scan is failed
alert(acquireModalResult.get_ErrorMessage());
break;
case 9: // scan is finished
let result = await swalConfirm('Continuare la scansione?', 'Si', 'No');
if (result.isConfirmed) {
// resolve();
break;
} else {
self.scanMore = false;
let params = {};
var imageIds = [];
const c = self.acquiredImages.get_Count();
l('Const c: '+c);
// for each acquired image
for (var i = 0; i < c; i++) {
// add image identifier to array of image identifiers
imageIds.push(self.acquiredImages.getItem(i).get_Id());
l('Acquired image id: ' + self.acquiredImages.getItem(i).get_Id());
l('Acquired image getitem[i]: '+self.acquiredImages.getItem(i));
l('Selfacquiredimages: '+self.acquiredImages);
l('Image ids');
l(imageIds);
// save images to an image file and return file data as a Base64 string
var imageFileAsBase64String = self.acquiredImages.getAsBase64String(nome_file + '.pdf', imageIds);
// l(imageFileAsBase64String);
params.fileToUpload = imageFileAsBase64String;
params.nomeFile = nome_file;
let connection = new Connection('scansioni/pdfupload', params, true);
connection.go().then(function (response) {
if (response.result == "success") {
alert("Scansione caricata con successo");
self.initLoadListaPdfUtente();
let PDFsidebaropen = false;
self.togglePdfSideBar(PDFsidebaropen);
self.acquiredImages.clear();
else {
console.log(response);
// resolve();
break;
while (acquireModalState !== 0);
catch (ex) {
alert('Catched error');
alert(ex);
finally {
if (twainDevice != null) {
// close the device
twainDevice.close();
resolve();
// close the device manager
self.twainDeviceManager.close();
Thank you.
Best Regards,
Luigi
Hi Luigi,
You have the problem because VintaSoft Web TWAIN service destroys/clears scanned images when TWAIN session is closed (TWAIN device manager is closed). Please close the TWAIN device manager only when scanned images are not necessary any more.
Ok, thank you.
Best regards,
Luigi
Best regards,
Luigi
