Two image viewer and thumbnail viewer in single document viewer
jwalit.katira
Post by jwalit.katira »
Hello
Can we have two image viewer and two thumbnail viewer in single document viewer which will open different images, the functionality like rotate and zoom should work on the selected image viewer . please find below image for reference
Jwalit Katira
Re: Two image viewer and thumbnail viewer in single document viewer
Hello Jwalit,
Vintasoft Web Document Viewer is a web control that allows to use 1 web image viewer and 1 thumbnail viewer.
If you want to use several viewers, you can create custom web control by yourself.
jwalit.katira
Hello Alex ,
As we are looking for multiple point so we have many queries for you , also we did use two document viewer in same page and it is working , do you have any suggestion not to do that way.
Jwalit Katira
Hello Jwalit,
If you created web control, which uses 2 image viewers, and your control is working correctly - please use your control, architecture is open.
