Mouse position on Image in AnnotationViewer
minalchaniara
Post by minalchaniara »
I am not able to get coordinates of Image while doing right click on image which is load in AnnotationViewer. It is giving AnnotationViewer coordinates. I am using below code for getting coordinates. Please help me on the same
private void AnnotationTool_MouseClick(object sender, VisualToolMouseEventArgs e)
     AnnotationVisualTool sAnnotationVisualTool = (AnnotationVisualTool)sender;
     //Point mp = sAnnotationVisualTool.ImageViewer.PointToImage(Control.MousePosition);
     if (e.Button == MouseButtons.Right)
         AnnotationViewer.AnnotationInteractionMode = AnnotationInteractionMode.Author;
             Point objPoint = new Point(e.X, e.Y);
             ReferencedImageAnnotationData objReferencedImageAnnotationData = new ReferencedImageAnnotationData();
             objReferencedImageAnnotationData.Image.SetImage(BitmapToVintasoftImage(global::Advantmed.RiskAdjustment.Application.Properties.Resources.AnnotationDot_Green));
             objReferencedImageAnnotationData.CreatedBy = Convert.ToString(NLPDataID);
             objReferencedImageAnnotationData.ModifiedBy = Convert.ToString(PageAnnotation);
             objReferencedImageAnnotationData.Name = "";
             objReferencedImageAnnotationData.Intent = strDiagnosis;
             objReferencedImageAnnotationData.Size = new SizeF((DotWidth / 2), (DotHeight / 2));
             objReferencedImageAnnotationData.Location = AnnotationViewer.PointFromControlToDip(objPoint);
             objReferencedImageAnnotationData.Border = false;
             objReferencedImageAnnotationData.CanMirror = false;
             objReferencedImageAnnotationData.CanResize = false;
             objReferencedImageAnnotationData.CanRotate = false;
             objReferencedImageAnnotationData.CanMove = true;
             if (objReferencedImageAnnotationData != null)
                 AnnotationViewer.AddAndBuildAnnotation(objReferencedImageAnnotationData);
             AnnotationViewer.FinishAnnotationBuilding();
Re: Mouse position on Image in AnnotationViewer
If you want to convert the screen point to the viewer point, you need to use the AnnotationViewer.PointToClient method.
If you want to convert the viewer point to the annotation point, you need to use the AnnotationViewer.PointFromControlToDip method.
