Console: Generate GS-128 barcode image.
Here is C# example that demonstrates how to generate GS-128 barcode image using VintaSoft Barcode .NET SDK:
namespace ConsoleApp1
    internal class Program
            // specify that GDI+ must be used as drawing engine
            Vintasoft.Barcode.GdiAssembly.Init();
            // an array of Application Identifiers, which should be used in GS-128 barcode
            Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue[] aiValues = new Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue[2];
            // create first Application Identifier
            Vintasoft.Barcode.GS1.GS1ApplicationIdentifier ai = Vintasoft.Barcode.GS1.GS1ApplicationIdentifiers.FindApplicationIdentifier("02");
            aiValues[0] = new Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(ai, "40529176710608");
            // create second Application Identifier
            ai = Vintasoft.Barcode.GS1.GS1ApplicationIdentifiers.FindApplicationIdentifier("400");
            aiValues[1] = new Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(ai, "WICAV240308BCN1");
            // create printable value of GS-128 barcode
            System.Text.StringBuilder printableValue = new System.Text.StringBuilder();
            foreach (Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue value in aiValues)
                printableValue.Append(value);
            // create barcode writer
            using (Vintasoft.Barcode.BarcodeWriter writer = new Vintasoft.Barcode.BarcodeWriter())
                // specify that barcode writer must create 24-bpp barcode image
                writer.Settings.PixelFormat = Vintasoft.Barcode.BarcodeImagePixelFormat.Bgr24;
                // specify that barcode writer must generate GS-128 barcode
                writer.Settings.Barcode = Vintasoft.Barcode.BarcodeType.Code128;
                writer.Settings.Value = Vintasoft.Barcode.GS1.GS1Codec.GS1_128.Encode(aiValues, writer.Settings);
                // specify that barcode writer must add barcode text under barcode image
                writer.Settings.ValueVisible = true;
                writer.Settings.UseLegacyVectorGenerator = false;
                writer.Settings.PrintableValue = printableValue.ToString();
                // generate image (with specified size) of GS-128 barcode
                Vintasoft.Imaging.VintasoftBitmap barcodeImage = writer.GetBarcodeAsVintasoftBitmap(491, 80, Vintasoft.Barcode.UnitOfMeasure.Pixels);
                // save generated image to a file
                Vintasoft.Barcode.ImageCodecs.Default.Encode(barcodeImage, "GS128BarcodeImage.png");
Here is VB.NET example that demonstrates how to generate GS-128 barcode image using VintaSoft Barcode .NET SDK:
Module Module1
    Sub Main()
        ' specify that GDI+ must be used as drawing engine
        ' an array of Application Identifiers, which should be used in GS-128 barcode
        Dim aiValues As Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue() = New Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(1) {}
        ' create first Application Identifier
        Dim ai As Vintasoft.Barcode.GS1.GS1ApplicationIdentifier = Vintasoft.Barcode.GS1.GS1ApplicationIdentifiers.FindApplicationIdentifier("02")
        aiValues(0) = New Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(ai, "40529176710608")
        ' create second Application Identifier
        aiValues(1) = New Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(ai, "WICAV240308BCN1")
        ' create printable value of GS-128 barcode
        Dim printableValue As New System.Text.StringBuilder()
        For Each value As Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue In aiValues
        Next
        ' create barcode writer
        Using writer As New Vintasoft.Barcode.BarcodeWriter()
            ' specify that barcode writer must create 24-bpp barcode image
            ' specify that barcode writer must generate GS-128 barcode
            ' specify that barcode writer must add barcode text under barcode image
            writer.Settings.ValueVisible = True
            writer.Settings.UseLegacyVectorGenerator = False
            ' generate image (with specified size) of GS-128 barcode
            Dim barcodeImage As Vintasoft.Imaging.VintasoftBitmap = writer.GetBarcodeAsVintasoftBitmap(491, 80, Vintasoft.Barcode.UnitOfMeasure.Pixels)
            ' save generated image to a file
            Vintasoft.Barcode.ImageCodecs.[Default].Encode(barcodeImage, "GS128BarcodeImage.png")
        End Using
    End Sub
End Module
