ReferencedImageAnnotationData Position getting changes on document.
ankit.acharya
Post by ankit.acharya »
Hi Team,
We are using below code to create a point on document.
private void AnnotationTool_MouseClick(object sender, VisualToolMouseEventArgs e)
     AnnotationVisualTool sAnnotationVisualTool = (AnnotationVisualTool)sender;
     //Point mp = sAnnotationVisualTool.ImageViewer.PointToImage(Control.MousePosition);
     if (e.Button == MouseButtons.Right)
         AnnotationViewer.AnnotationInteractionMode = AnnotationInteractionMode.Author;
             Point objPoint = new Point(e.X, e.Y);
             ReferencedImageAnnotationData objReferencedImageAnnotationData = new ReferencedImageAnnotationData();
             objReferencedImageAnnotationData.Image.SetImage(BitmapToVintasoftImage(global::Advantmed.RiskAdjustment.Application.Properties.Resources.AnnotationDot_Green));
             objReferencedImageAnnotationData.CreatedBy = Convert.ToString(NLPDataID);
             objReferencedImageAnnotationData.ModifiedBy = Convert.ToString(PageAnnotation);
             objReferencedImageAnnotationData.Name = "";
             objReferencedImageAnnotationData.Intent = strDiagnosis;
             objReferencedImageAnnotationData.Size = new SizeF((DotWidth / 2), (DotHeight / 2));
             objReferencedImageAnnotationData.Location = AnnotationViewer.PointFromControlToDip(objPoint);
             objReferencedImageAnnotationData.Border = false;
             objReferencedImageAnnotationData.CanMirror = false;
             objReferencedImageAnnotationData.CanResize = false;
             objReferencedImageAnnotationData.CanRotate = false;
             objReferencedImageAnnotationData.CanMove = true;
             if (objReferencedImageAnnotationData != null)
                 AnnotationViewer.AddAndBuildAnnotation(objReferencedImageAnnotationData);
             AnnotationViewer.FinishAnnotationBuilding();
Same way we are drawing again with below method and location is getting changed. We are getting point on different location.
Point objPoint = new Point(Convert.ToInt32(drPagewise[i]["X"]), Convert.ToInt32(drPagewise[i]["Y"]));
objReferencedImageAnnotationData.Location = AnnotationViewer.PointToClient(objPoint);
objReferencedImageAnnotationData.Size = new Size(Convert.ToInt32(drPagewise[i]["Width"]), Convert.ToInt32(drPagewise[i]["Height"]));
objReferencedImageAnnotationData.ToolTip = Tooltip;
objReferencedImageAnnotationData.CanMove = (clsCoding.StageID == 5 || clsCoding.StageID == 11 || clsCoding.StageID == -97 || clsCoding.StageID == -99) ? false : true;
Thank you,
Ankit Acharya
Re: ReferencedImageAnnotationData Position getting changes on document.
Hello Ankit,
Please send us (to support@vintasoft.com) a small console project, which demonstrates the problem, and we will try to help you.
