Version 15.3 of VintaSoft Barcode .NET SDK has been released.
What's new in this version:
  • .NET development
    • Added the support for .NET 10.0 in Windows, Linux, macOS.
    • Now Vintasoft.Barcode.SkiaSharp assembly uses SkiaSharp 3.119.0.
Version 15.3.1.1 of VintaSoft Barcode .NET SDK has been released.
  • .NET development
    • Now Vintasoft.Barcode.ImageSharp assembly uses SixLabors.ImageSharp 3.1.12.
    • Fixed the bug in algorithm that recognizes rotated Pharmacode barcodes.
    • Fixed the bug in algorithm that recognizes short "Interleaved 2 of 5" barcodes.
    • Fixed the bug in algorithm that recognizes EAN barcodes.
Version 15.3.2.1 of VintaSoft Barcode .NET SDK has been released.
  • .NET development
    • Fixed the bug in algorithm that decodes 1-bpp black-white image.
Version 15.3.3.1 of VintaSoft Barcode .NET SDK has been released.
  • .NET development
    • Added the support for the L8 pixel format in the ImageSharpConverter class.
    • Fixed the bug that could occur on Linux when the ReaderSettings.RecognitionTimeout property is used.
Version 15.3.4.1 of VintaSoft Barcode .NET SDK has been released.
  • .NET development
    • Improved the algorithm that recognizes Pharmacode barcodes.
    • Fixed the bug in algorithm that calculates value of FixedPatternDamage parameter for DataMatrix barcode in ISO 15415 barcode print quality test.
Version 15.3.5.1 of VintaSoft Barcode .NET SDK has been released.
  • .NET development
    • Improved the algorithm that recognizes EAN13 barcodes.
Version 15.3.6.1 of VintaSoft Barcode .NET SDK has been released.
  • .NET development
    • Added the ability to recognize QR Code barcodes, which are generated by closed system applications and contain private data. Added the Vintasoft.Barcode.BarcodeInfo.QRPrivateDataValueItem class, which allows to get/set private data in QR Code barcode.
    • Significantly increased the recognition speed of DataMatrix barcodes if image with barcodes contains a lot of noise.
Version 15.3.7.1 of VintaSoft Barcode .NET SDK has been released.
  • .NET development
    • Added a new ISO15415QualityTestManager class that simplifies the testing of 2D barcode print quality in accordance with the ISO15415 standard.
    • Fixed the bug in algorithm that recognizes barcodes "Micro PDF417 CC-A (GS1 2D Component)".
    • Fixed the bug in algorithm that generates barcode "Micro PDF417 CC-A (GS1 2D Component)".
