Drawing a line
t.abbach
Drawing a line
Post by t.abbach »
I want to press on the left mouse button and then i want to draw a line.
when i put my finger of the left mouse button then the line must stop ?
how can i do that
Yuri
Re: Drawing a line
Post by Yuri »
It's possible to draw Line annotation as following in Annotation Demo example:
- You choose line annotation
-Click and hold left mouse button on necessary position in an image, then pull the mouse: drawing starts
- Release left mouse button: drawing stops
You can also use Lines annotation (next one after Line annotation).
Here is possible the following:
- You choose lines annotation
-Click left mouse button on necessary position in an image, then pull the mouse: drawing starts
- Double click left mouse button: drawing stops
t.abbach
Re: Drawing a line
Post by t.abbach »
When i draw a line in your demo, the line starts with the left mouse button and stops with the right mouse button.
i want to start drawing a line with the left mouse button and hold my finger on the left mouse button till i want to stop the line.
how do i do that ?
Yuri
Re: Drawing a line
Post by Yuri »
You should create custom annotation based on standard one (please read the library documentation "Getting Started - Create a custom annotation").
Please try one of the variants of c# code below, both allow start and finish drawing with left mouse click:
//based on LinesAnnotation
class MyLineAnnotation : LinesAnnotation
    protected override void OnBuilding(MouseEventArgs mouse, MouseActions action)
        if (action == MouseActions.Click && Points.Count == 3)
            FinishBuilding(mouse.Location);
            base.OnBuilding(mouse, action);
//based on LineAnnotation
class MyLineAnnotation2 : LineAnnotation
    bool _skipFirstUp;
    protected override void OnStartBuilding(PointF point)
        _skipFirstUp = false;
        base.OnStartBuilding(point);
        if (action == MouseActions.Up && !_skipFirstUp)
            //Skip first Mouse Up action
            _skipFirstUp = true;
            return;
t.abbach
Re: Drawing a line
Post by t.abbach »
thank a lot it works.
