Divide by zero error
BillG
Post by BillG »
I finally figured out what I was doing wrong and now it is saving multiple pages properly. Every one and awhile though, the user gets a divide by zero error, they exit the program, log back in and it works fine. Later just out of the blue, after working for a while it happens again. Here is the code.
if (vsTwain1.FeederLoaded)
vsTwain1.ShowIndicators = true;
while (vsTwain1.AcquireModal())
pictureBox1.Image = vsTwain1.GetCurrentImage();
vsTwain1.SaveImage(0, dirPath + filePath);
catch (TwainException ex)
if (vsTwain1.ErrorCode != Vintasoft.Twain.ErrorCode.None)
MessageBox.Show(vsTwain1.ErrorString);
MessageBox.Show(ex.Message);
myController.SaveScannedRecord(Int32.Parse(rdType.ToString()), filePath, DescriptionTextBox.Text.ToString(), numOfPages);
vsTwain1.StopDevice();
Re: Divide by zero error
Hello Bill,
First of all you must dispose the image in the PictureBox when you replace it.
Here is correct code:
      if (pictureBox1.Image != null)
        pictureBox1.Image.Dispose();
        pictureBox1.Image = null;
Could you tell me in which line of code the "divide by zero" error occurs?
BillG
Post by BillG »
That solved the problem of the divide by zero error. When the user scans a one page document everyone works fine, but when the user scans a document with two pages it actually scans the first page multiple times into the file. I can't duplicate this on my system. Tthey and I are using a HP Scanjet N6010 and using the WIA drivers.
Bill
Hello Bill,
Please try to download and use version 2.0 driver for HP N6010 scanner from this link:
http://driverscollection.com/?H=ScanJet%20N6010&By=HP
and let me know results.
