vsTwain1.OpenDataSource();
vsTwain1.UnitOfMeasure = UnitOfMeasure.Inches;
vsTwain1.Brightness = vsTwain1.BrightnessMaxValue;
vsTwain1.SetImageLayout(1, 1, 6, 4);
I am trying to scan a card that is 6 inches and 4 inches wide and am getting an error in setting the image. What am I doing wrong?
Bill
Getting error in setting image layout
Re: Getting error in setting image layout
Hi Bill,
Maybe your scanner does not support image layout feature? Please send a log file generated by the library to our support team at support@vintasoft.com.
I too am getting the same error I presume the scanner does have capability to be able to do this since the error does not say "Capability is not supported." (as it does for set pagesize) - Here is the code at which it errors and the last few lines of my log file:
VsTwain1.SetImageLayout(0, 0, 3, 4)
17/06/2009 09:15:38 PTW90-5
17/06/2009 09:15:39 PTW2 msg=0xf (WM_PAINT) hwnd=0xb0bac wparam=0x0 lparam=0x0 result=0x0
17/06/2009 09:15:39 PTW90-5
17/06/2009 09:15:39 PTW2 msg=0xf (WM_PAINT) hwnd=0x20c48 wparam=0x0 lparam=0x0 result=0x0
17/06/2009 09:15:39 PTW2 msg=0x202 (WM_LBUTTONUP) hwnd=0xb0bac wparam=0x0 lparam=0x13002e result=0x0
17/06/2009 09:15:39 SetCap(258,5,0)
17/06/2009 09:15:39 SetCap result = 0
17/06/2009 09:15:39 GIL1
17/06/2009 09:15:39 GIL2 0
17/06/2009 09:15:39 GIL3 1 1 1 0 0 8.5 14
17/06/2009 09:15:39 SIL1 0 0 3 4
17/06/2009 09:15:39 SIL2
17/06/2009 09:15:39 SIL3 2
many thanks
many thanks
Are you sure that you have set inches as unit of measure?
Your device has sent extended information about problem with image layout to application. Please download latest version (5.0.3.5) of VintaSoftTwain.NET Library from our site, generate new log file and send it to support@vintasoft.com.
Yes I am sure it is in inches, i set them to inches and then Got layout to see what the current size was during debug.
VsTwain1.UnitOfMeasure = UnitOfMeasure.Inches
Dim lay As String = VsTwain1.GetImageLayout()
Can you link where i ought to download the new version? I have bought the version 5.0.3.3 , and i can only see a download for the evaluation dll.
However I will still send you the 5.0.3.3 log file.
many thanks
many thanks
You can download the latest version of VintaSoftTwain.NET Library from this link: http://www.vintasoft.com/zip/VSTwainNet50.zip
I have the same problem. Error when setting image layout.
here is my code:
VSTwain1.OpenDataSource()
VSTwain1.Resolution = 150
VSTwain1.PdfImageCompression = PdfImageCompression.Auto
VSTwain1.PixelType = PixelType.GRAY
VSTwain1.UnitOfMeasure = UnitOfMeasure.Inches
VSTwain1.SetImageLayout(0, 0, 8.5, 11)
VSTwain1.Acquire()
here is the twain log
TWAIN_32.DLL - MESSAGE - CTwunk ::AppInitialize - Reset Log
TWAIN_32.DLL - MESSAGE - CTwunk ::OpenServer - Starting Thunker
TWAIN_32.DLL - MESSAGE - CTwunk ::CloseServer - Why Can't We Find The Thunker Window?
TWAIN_32.DLL - MESSAGE - DSM --DsmEntryDiagExit (RC = 0, CC = 0)
TWAIN_32.DLL - MESSAGE - CTWTRACE--VintaSoftTwain.NET(2) to NULL:
TWAIN_32.DLL - MESSAGE - CTWTRACE--CONTROL, IDENTITY, GETFIRST
TWAIN_32.DLL - MESSAGE - CTWTRACE--CONTROL, IDENTITY, GETNEXT
TWAIN_32.DLL - MESSAGE - DSM --DsmEntryDiagExit (RC = 7, CC = 0)
TWAIN_32.DLL - MESSAGE - CTWTRACE--CONTROL, IDENTITY, GETDEFAULT
TWAIN_32.DLL - MESSAGE - CTWTRACE--CONTROL, IDENTITY, OPENDS
TWAIN_32.DLL - MESSAGE - CTWTRACE--VintaSoftTwain.NET(2) to WIA-Brother MFC-8220 USB(3):
TWAIN_32.DLL - MESSAGE - CTWTRACE--CAPABILITY, GET, XRESOLUTION
TWAIN_32.DLL - MESSAGE - CTWTRACE--CAPABILITY, SET, XRESOLUTION
TWAIN_32.DLL - MESSAGE - CTWTRACE--CAPABILITY, GET, YRESOLUTION
TWAIN_32.DLL - MESSAGE - CTWTRACE--CAPABILITY, SET, YRESOLUTION
TWAIN_32.DLL - MESSAGE - CTWTRACE--CAPABILITY, GET, PIXELTYPE
TWAIN_32.DLL - MESSAGE - CTWTRACE--CAPABILITY, SET, PIXELTYPE
TWAIN_32.DLL - MESSAGE - CTWTRACE--CAPABILITY, GET, UNITS
TWAIN_32.DLL - MESSAGE - CTWTRACE--CAPABILITY, SET, UNITS
TWAIN_32.DLL - MESSAGE - CTWTRACE--IMAGE, IMAGELAYOUT, SET
TWAIN_32.DLL - MESSAGE - DSM --DsmEntryDiagExit (RC = 2, CC = 0)
TWAIN_32.DLL - MESSAGE - CTWTRACE--CONTROL, EVENT, PROCESSEVENT...
TWAIN_32.DLL - MESSAGE - DSM --DsmEntryDiagExit (RC = 5, CC = 0)
TWAIN_32.DLL - MESSAGE - CTWTRACE--CONTROL, IDENTITY, CLOSEDS
TWAIN_32.DLL - MESSAGE - CTWTRACE--CONTROL, PARENT, CLOSEDSM
TWAIN_32.DLL - MESSAGE - DSM --DsmEntryDiagExit (RC = 0, CC = FFFF)
This is the capabilities list:
Data Source information
*: Brother
Product family: Twain Data Source On WIA
Product name: WIA-Brother MFC-8220 USB
TWAIN version: 1.9
TWAIN 2.0 compatible: False
Flatbed present: True
ADF present: True
Current pixel type: Gray
Supported pixel types: BW, Gray
Current resolution: 100 dpi
Supported resolutions: 100, 150, 200, 300, 400, 500, 600, 1200
Current page size: None
Current unit of measure: Inches
Supported units of measure: Inches, Pixels
Current image layout in Inches: (0; 0) - (8.5; 14)
Data Source capabilities:
XferCount (read/write)
Current value: 0
ICompression (read/write)
Current value: 0
Supported values: 0
IPixelType (read/write)
Current value: 1
Supported values: 0, 1
IUnits (read/write)
Current value: 0
Supported values: 0, 5
IXferMech (read/write)
Current value: 0
Supported values: 0, 1, 2
FeederEnabled (read only)
Current value: 0
FeederLoaded (read/write)
Current value: 1
SupportedCaps (read only)
Supported values: 1, 256, 257, 258, 259, 4098, 4099, 4101, 4103, 4107, 4110, 4111, 4116, 4353, 4355, 4364, 4369, 4370, 4374, 4375, 4376, 4377, 4380, 4383, 4384, 4387, 4388, 4389, 4395
AutoFeed (read/write)
Current value: 0
Indicators (read/write)
Current value: 1
UIControllable (read/write)
Current value: 1
DeviceOnline (read/write)
Current value: 1
EnableDsUiOnly (read/write)
Current value: 0
IBrightness (read/write)
Current value: 1.525879E-05
Default value: 0
Range of supported values: min = -1000, max = 1000, step size = 1
IContrast (read/write)
Default value: 0
IImageFileFormat (read/write)
Current value: 2
Supported values: 2, 6
IPhysicalWidth (read/write)
Current value: 8.5
IPhysicalHeight (read/write)
Current value: 14
IXNativeResolution (read/write)
Current value: 300
IYNativeResolution (read/write)
Current value: 600
IXResolution (read/write)
Current value: 100
Supported values: 100, 150, 200, 300, 400, 500, 600, 1200
IYResolution (read/write)
Current value: 100
IBitOrder (read/write)
Current value: 1
Supported values: 1
IPixelFlavor (read/write)
Current value: 0
IPlanarChunky (read/write)
Current value: 0
IThreshold (read/write)
Current value: 128
Default value: 128
Range of supported values: min = 0, max = 255, step size = 1
IXScaling (read/write)
Current value: 1
Default value: 1
Range of supported values: min = 1, max = 1, step size = 1
IYScaling (read/write)
Current value: 1
Default value: 1
IBitDepth (read/write)
Current value: 8
Supported values: 1, 8
Thanks for the help.
here is my code:
VSTwain1.Acquire()
*: Brother
TWAIN version: 1.9
ADF present: True
Current value: 0
Current value: 0
Supported values: 0
Current value: 1
IUnits (read/write)
Current value: 0
Current value: 0
Current value: 0
Current value: 1
Current value: 0
Current value: 1
Current value: 1
Current value: 1
Current value: 0
Default value: 0
Default value: 0
Current value: 2
Current value: 8.5
Current value: 14
Current value: 300
Current value: 600
Current value: 100
Current value: 100
Current value: 1
Supported values: 1
Current value: 0
Current value: 0
Current value: 128
Default value: 128
Current value: 1
Default value: 1
Current value: 1
Default value: 1
Current value: 8
Please try to use TWAIN driver for your scanner, WIA drivers is not 100% compatible with TWAIN specification.
