Javascript capabilities
geovan
Post by geovan »
I'm having problems loading values for capType Array and Enumeration (supported resolutions, page sizes, etc.).
Can you please provide a javascript example?
Geovan.
Re: Javascript capabilities
Hello Geovan,
I don't know why VBArray object does not accept array from ActiveX. We will try to solve this problem in next version of ActiveX and maybe we will add new methods specially for JavaScript which will return array as string.
geovan
Post by geovan »
Hello Alexander,
Please take into account that capItems, GetResolutions(), etc. does not work in JavaScript, JScript and VBScript.
Thanks for your reply,
Geovan.
Hello Geovan,
Please try to use version 5.0 of VintaSoftTwain ActiveX.
geovan
Post by geovan »
Hello Alexander,
I'v tryied using version 5.0 but I got the same issues from JavaScript and VBScript.
Geovan.
Hello Geovan,
You should use the ConvertArrayToString method. Here is an example:
alert("Supported resolutions: " + VSTwain1.ConvertArrayToString(VSTwain1.GetResolutions()));
geovan
Post by geovan »
Hello Alexander,
A minor modification, parameter Digits After Point is required:
alert("Supported resolutions: " + VSTwain1.ConvertArrayToString(VSTwain1.GetResolutions(), 0));
It is working fine now!
Thank you very much,
Geovan.
