Reading Exif/GPS data from loaded image
communi
Post by communi »
is there a piece of VB sample code how to read the in Exif data stored GPS data (Lat, Long, Alt etc.)of a jpg file which is currently displayed in ImageViewer and display the GPS data in a textbox etc.? The helpfile was not really helpful in this case.... ;)
Regards,
Communi
Here is a snippet of code which shows how to get information about EXIF tags of JPEG file:
Imports System.IO
Imports Vintasoft.Imaging
Module Module1
    Sub Main()
        Using jpegStream As FileStream = New FileStream("..\..\Exif.jpg", FileMode.Open, FileAccess.Read)
            Using jpeg As JpegFile = New JpegFile(jpegStream)
                If exif Is Nothing Then
                    Console.WriteLine("JPEG file does not have EXIF data.")
                Else
                    WriteTagsData("EXIF", exif.ExifTags)
                    WriteTagsData("GPS", exif.GpsTags)
            End Using
        End Using
        Console.WriteLine("Press any key to continue...")
        Console.ReadKey()
    End Sub
    Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection)
        If tags.Count = 0 Then
            Console.WriteLine(String.Format("No {0} data.", tagsName))
        Else
            Console.WriteLine(String.Format("{0} data [{1}]:", tagsName, tags.Count))
            For i = 0 To tags.Count - 1
                Console.WriteLine(String.Format("- {0}", tags(i)))
            Next
        Console.WriteLine()
    End Sub
End Module
communi
Post by communi »
I tried this code changed to WinForms code - but no luck. Instead of the GPS data in the Textbox is always only "- Vintasoft.Imaging.Codecs.Tiff.TiffTag" displayed( and the photo has GPS data). If I take a photo without geotags it recognises this correctly and displays "No GPS data". So whats wrong?
Here is the code I have used:
Imports System.IO
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
    Using jpegStream As FileStream = New FileStream("..\..\geotag005.jpg", FileMode.Open, FileAccess.Read)
                TextBox1.Text = "JPEG file does not have EXIF data."
            Else
        End Using
    End Using
End Sub
Public Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection)
        TextBox1.Text = String.Format("No {0} data.", tagsName)
    Else
        TextBox1.Text = String.Format("{0} data [{1}]:", tagsName, tags.Count)
            TextBox1.Text = String.Format("- {0}", tags(i)) & vbCrLf
        Next
End Sub
You need to use this code:
            Else
        End Using
    End Using
End Sub
Private Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection)
        TextBox1.Text = TextBox1.Text + String.Format("No {0} data.", tagsName) & vbCrLf
    Else
        TextBox1.Text = TextBox1.Text + String.Format("{0} data [{1}]:", tagsName, tags.Count) & vbCrLf
        Dim tag As TiffTag
            tag = tags(i)
            TextBox1.Text = TextBox1.Text + String.Format("- Name={0}, Id={1}, Type={2}, Data={3}", tag.Name, tag.Id, tag.Type, tag.Data) & vbCrLf
        Next
    TextBox1.Text = TextBox1.Text + vbCrLf
End Sub
communi
Post by communi »
Thanks, this works fine! But there is no "real" content, no real data displayed, only this:
GPS data [7]:
- Name=InteroperabilityIndex, Id=1, Type=Ascii, Data=N
- Name=GPSLatitude, Id=2, Type=Rational, Data=Vintasoft.Imaging.Codecs.Tiff.Rational[]
- Name=GPSLongitudeRef, Id=3, Type=Ascii, Data=E
- Name=GPSLongitude, Id=4, Type=Rational, Data=Vintasoft.Imaging.Codecs.Tiff.Rational[]
- Name=GPSAltitudeRef, Id=5, Type=Byte, Data=0
- Name=GPSAltitude, Id=6, Type=Rational, Data=83889 / 278
- Name=GPSTimeStamp, Id=7, Type=Rational, Data=Vintasoft.Imaging.Codecs.Tiff.Rational[]
Is this normal?
You need to convert arrays to string.
Here is a snippet of code:
    Else
        Dim tag As TiffTag
        Dim tagData As Object
        Dim tagDataAsArray As Array
        Dim tagDataAsString As String
        ' for each tag in tag collection
            ' get tag
            tag = tags(i)
            ' get tag data
            tagData = tag.Data
            ' if tag data is array
            If IsArray(tagData) Then
                tagDataAsString = "[ "
                tagDataAsArray = CType(tagData, Array)
                For j = 0 To tagDataAsArray.Length - 1
                    tagDataAsString = tagDataAsString + tagDataAsArray(j).ToString + "; "
                Next
                tagDataAsString = tagDataAsString + "]"
            ' if tag data is NOT array
            Else
                tagDataAsString = tagData.ToString()
            ' add information about tag to textbox
            TextBox1.Text = TextBox1.Text + String.Format("- Name={0}, Id={1}, Type={2}, Data={3}", tag.Name, tag.Id, tag.Type, tagDataAsString) & vbCrLf
        Next
End Sub
communi
Post by communi »
now it works great!! Thank you! I only have to find a way to convert the data values to a human readable format ;) Any ideas? :D
But one question. The Name of the first data is "InteroperabilityIndex" but the correct name should be "GPSLatitudeRef", why the code doesn't recognize this? The exif data in the image are correct, other software shows this name correctly as "GPSLatitudeRef"
GPS data [7]:
- Name=GPSLatitude, Id=2, Type=Rational, Data=[ xxxxx ]
- Name=GPSLongitude, Id=4, Type=Rational, Data=[xxxxx]
- Name=GPSTimeStamp, Id=7, Type=Rational, Data=[ 15 / 1; 47 / 1; 32 / 1; ]
We have fixed bug in version 4.3.35.5 of SDK and now your code will work correctly.
But the following code is better:
            Else
                WriteTagsData("EXIF", exif.ExifTags, GetType(ExifTagId))
                WriteTagsData("GPS", exif.GpsTags, GetType(GpsTagId))
        End Using
    End Using
End Sub
Private Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection, ByRef tagIdEnumType As Type)
    Else
        Dim tag As TiffTag
            ' get tag
            tag = tags(i)
            ' get tag data
            tagData = tag.Data
                Next
            Else
            TextBox1.Text = TextBox1.Text + String.Format("- Name={0}, Id={1}, Type={2}, Data={3}", tag.GetName(tagIdEnumType), tag.Id, tag.Type, tagDataAsString) & vbCrLf
        Next
End Sub
communi
Post by communi »
Alex,
Thank You!!! :) Now it works fine with the latest version, great job!!!!!!
js95007
Post by js95007 »
Hey guys don't know if this post is still active, but still worth a shot
I have tried to use the latest code Alex gave, but ended up with three errors.
These probably where trivial errors on my part (I'm something of a novice ;) ) but I haven't been able to solve it, so here goes:
Using jpeg As JpegFile = New JpegFile(jpegStream) --- "jpeg is not defined"
Private Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection, ByRef tagIdEnumType As Type) --- "TiffTagCollection is not defined"
Dim tag As TiffTag --- "TiffTag is not defined"
Hope you can shed some light, I have spent the last three days endlessly searching for how to extract GPS info from an image in Visual Basic :?
Thanks for any help you can give, it will be greatly appreciated
